Question about Cisco 1720 Router
I have a Cisco 1720 router. I think I installed the wrong configuration files or I typed in a sentex error during reconfiguration and now all I can see on the screen is garbaled symbols. For example: xðxþ?xø?xø?xø???xþxøøø?øxøø??ø?øøxøø?ø??ø?x?ø?øø??xà?ø?øøøøxøø??ø??øxøøøø??xø?xø?xø?xðxþxþøø?xþ???ø??ø??ø??ø??øxà?øø?xà What can I do?
Posted by felixflemons on
Wayne Moore
  • 39 Answers
It looks like the baud rate is wrong. make sure your terminal is set to 9600 8 N 1 , then reconnect and reset the router
Posted on Jan 24, 2010
Reinstalling cisco m20 0n vista
Is it re-installation of complete network or you are just trying to add Vista computer to the network?
Is it a complete re-installation then you can reset the router to factory default settings and then try to reconfigure it.
You can run Cisco connect software on the main computer or you can also reinstall it manually,
Read how to reconfigure router manually,
If you trying to connect Wireless Vista computer to the network then you can simply search for the WiFi and then join the wireless network on Windows Vista computer
Jun 05, 2012 | Linksys by Cisco Cisco Valet Plus Wireless...
Tip
877 router factory reset woes
Question:<br> We've recently changed <a href="http://www.3anetwork.com/cisco-c2951-vsec-sre/k9-price_p267.html"><b>C2951-VSEC </b></a>data line providers and now have some Cisco 877 routers we'd like to reconfigure and use at other sites. Although we own these, they were configured by our old data line providers, I'm having a hard time of resetting them to factory defaults and am after some advice.<br> The simple, hold down the reset button until it restarts does not work.<br> If I press the reset button within 5 seconds of power up to load the default rom image, I get the below:<br> System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE<br> Technical Support: http://www.cisco.com/techsupport<br> Copyright (c) 2006 by cisco Systems, Inc.<br> C870 series (Board ID: 1-148) platform with 131072 Kbytes of main memory<br> Booting flash:c870-advipservicesk9-mz.124-24.T.bin<br> Error opening: flash:c870-advipservicesk9-mz.124-24.T.bin<br> System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE<br> Technical Support: http://www.cisco.com/techsupport<br> Copyright (c) 2006 by cisco Systems, Inc.<br> C870 series (Board ID: 1-148) platform with 131072 Kbytes of main memory<br> Booting flash:/c870-advsecurityk9-mz.124-24.T6.bin<br> Self decompressing the image : ############################################################################## [OK]<br> I assume from this the required bin has either been removed, renamed or overwritten.<br> As soon as the router boots it requires a password and I dont have the password to be able ftp files in and out of it.<br> Hope you guys can help.<br> Answer: <br> this should work indeed.<br> take a look here:http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a0080174a34.shtml <a href="http://www.3anetwork.com/cisco-cisco3925/k9-price_p284.html"><b>Cisco 3925</b></a>
on Aug 28, 2013 | Computers & Internet
Tip
Cisco 3925 Router Password Recovery
TheCisco 3925 router is part of a family of networking equipment produced byCisco, which has been a network equipment giant for many years. Used 3925routers are available on the Internet at reasonable prices, so acquiring one isnot difficult. However, if the password is unknown or lost, reconfiguration isimpossible until the password is reset or recovered.
Cisco has built in aprocedure for rescuing lost or forgotten passwords or entering new passwords.
ThingsYou'll Need: Serial to RJ-45 cable;Terminal emulation software
Instructions
1.Connect your computer to the router with the blue serial-to-RJ-45 cable thatcame with the router.
The 9-pin D-shell end connects to your computer's serialport, while the RJ-45 end connects to the console jack on the router.
The RJ-45end resembles a slightly larger telephone jack connector.
2.Turn on your computer and establish a terminal session to the 3925. You can use any terminal emulator, and many are freely available on the Internet.
Configure the session settings as follows:9600baud8data bitsNoparity1stop nonflowering controllable router's power cable into an electrical outlet, and as the 3925 boots, you should see the Cisco boot messages.
If you don't see any output on your computer's terminal session, check your settings on the session and restart itif necessary.
Press "Break" within 30 seconds of powering on the router to enter rommon (rom monitor) mode.
3.Type "confreg 0x2142" and press "Enter" at the "rommon1>" prompt. This will cause the router to boot from its internal flashmemory without loading the configuration into memory.
At the following"rommon 2>" prompt, type "reset" and press"Enter."
This will cause the router to reload and ignore thepreviously saved configuration file.
4.Respond "no" and press "Enter" when prompted for responsesto enter the initial dialog or basic management setup.
Type "enable"and press "Enter" at the following "Router>" prompt.This will put you into enable mode and display the "Router#" prompts.Copy the non-volatile memory into memory with the "copy start up-config running-config" command, followed by the "Enter" key. Type"sho run" at the prompt and press "Enter" to display the current configuration, including the passwords, some of which may be encrypted.
5.Type "config t" at the prompt and press "Enter." At the"Router(config)#" prompt, type "enable secret <pswd>"-- where "pswd" is the password -- and press "Enter." Atthis point, your enable password is reset. Press "Ctrl" +"z" to return to the "Router#" prompt.
6.Type "config t" at the "Router#" prompts and presses"Enter." At the "Router(config)#" prompt, type"config-register 0x02102" and press "Enter" to reset theboot register to its normal setting. Press "Ctrl" + "z" toleave configuration mode. Type "copy running-config startup-config"and press "Enter" to save your changes. Reboot the router and youshould be able to login with your password.
on Sep 05, 2011 | Computers & Internet
Help!!!!!!!!!!!
Leave the user name blank and enter the password admin ( admin once only ).
Try this.
If that doesn't work then search for the Cisco connect software on your main computer. You might have installed the cisco connect software on your main computer while installing your router.
If it is windows computer then cisco connect software might be under All Programs.
If is a MAC computer then cisco connect might be under Applications.
Open cisco connect software.
Click on router settings. You will see the router name and password. If you click on Advanced settings, it will open the setup page.
If nothing is working then you will need to reset the router and reconfigure it.
Remember once you reset the router, you will need to reconfigure it from the scratch.
Click to see more information about cisco connect software
Apr 12, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Trying to configure my Linksys WRT120N router, but when I click 'Save Settings' I get an error message (324). What's wrong?
I think you can try upgrading the firmware on your router,
Connect the computer to the router.
Download the latest firmware.
Open the setup page of the router and upgrade the firmware.
After upgrading the firmware, reset the router and reconfigure it manually.
See How to upgrade firmware on Linksys router.
Watch video: Linksys router setup
Mar 27, 2012 | Linksys WRT120N Router
I accidentally reset my wireless G WRT54g router, how can restore it?
Not unless you made a backup configuration file. So unfortunately you will need to reconfigure your wireless router. The main points you should configure are...
  • Change the default password to login to your router configuration
  • Change the SSID (optional)
  • Enable wireless security WPA2 / PSK (keep out unauthorized users)
You can configure it manually or download the utility from Linksys / Cisco website which will walk you through the configuration.
Comment back if you need help configuring it.
Nov 07, 2011 | Linksys Wireless-G WRT54G Router
Help me access linksys router website. if i type 192.168.1.1 an error appears.
Typing the IP address will not get you to the Linksys WEB site.
The Linksys/Cisco WEB site is -
http://home.cisco.com/en-us/wireless/
The configuration URL for for configuring the Linksys wireless settings is -
http://192.168.1.1
The default login = admin
The default password = admin
Sep 11, 2010 | Linksys WRT160N Wireless Router
Cisco 1841 Freezing at System Configuration Dialog
Try resetting its firmware or try booting it in another location.
May 08, 2009 | Cisco (1841) Router (cisco1841)
Bootup Router and then nothing
Your router is in the wrong mode. You need to change this by changing the conf-register to 0x2102
at the rommon prompt type in
config-reg 0x2102
reboot
If there are any errors you can get the correct syntax by typing ? at the rommon prompt the line number will go up on every line.
The way to get into rommon mode is by pressing the break key from Hyperterminal as the router is rebooting. So make sure you don't do this by accident. If you do just reboot by power cycling.
Your Startup Config should be unchanged, but you need to be very careful what you do in rommon mode it is easy to blat stuff.
Any changes you make once you get into the command (enable) mode should be saved by
Any problems just let me know.
good feed back would be much appreciated.
Carrie
Dec 05, 2008 | Computers & Internet
Cisco 1720 Router Logo
202 people viewed this question
Top Cisco Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Mike
Jax Planet
Jax Planet
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
