I am having canon pixma ip1300 inkjet printer. it worked properly till 13th...
Things you will need.
Needle nose pliers.
Paper towels
97% rubbing alcohol
Plastic gloves.
Flashlight
Disposable waste container, lined with plastic.
Disposable plastic tray about 6x9 or thereabouts.
Plenty of ventilation, outside if need be.
a. With the printer on, open this lid as if to change cartridges.
b. Turn Printer off. Unplug the printer. Unattach the communication
cable. You will be moving it to a work area with excellent ventilation,
such as outside.
c. At the far right where the the cartridges normally park themselves
when not printing you will see a platform with rectangular
compartments. When the cartridges park, this platform rises, seals off
the nozzle area and captures any leaking ink, which till happens today.
d. Examine the platform with your flashlight and you will see what
looks like sponges in the compartments. This material with holes in it,
like a sponge, is plastic.Put on your gloves.
e. Place a paper towel folded over on itself underneath this platform as best you can to catch any spilling ink.
f. Use paper towels soaked in alcohol slightly and your needle nose pliers to push
the paper towel into each compartment, gently at first, until the majority of ink is
removed.
g. This will take quite a long time and plenty of paper towels and patience. So be
patient and ready for the long haul. Avoid smoking and the fumes.
h. At some point the sponge material, itself, may become dislodged and loose.
When you witness this, go ahead and remove it carefully using your needle nose
pliers and place it on some paper towels placed inside your disposable plastic tray.
i When you have one or both, if needed or more sponges removed and in the tray,
pour alcohol over these until the ink runs pretty thin. Leave to everything to dry.
i. Use a paper towel damp with alcohol and your pliers to clean out the compartment and its sides as best you can.
j. When you have completed these tasks allow the compartments and sponges to dry.
k. You are ready to reassemble the sponges into the compartments. Do so now.
l. Nearly done; take a towel wet with alcohol and hold it very gently
against the bottom of the ink cartridge until ink flows freely onto the
paper towel. If its stubborn, knock
the cartridge gently but sharply against a hard surface with the alcohol soaked towel held against the nozzle area.
k. Re insert the cartridges now.
l. Return the printer to its working location, attach power, attache the comm cable and with the lid closed apply power.
m. Run your printer through its normal setup routine, deep clean the
print heads, run a nozzle check and finally do a print head alignment.
m. Your Printer is now ready to be used again.
Thank you,
Worldvet
