Question about Reddy Heater-30-55,000 BTU Variable
It will only run when I take the top cover off
It is either the photo eye is dirty or bad or the volume adjustment needs adjustment.
Posted on Jan 10, 2013
Clean or reposition photo eye.
Posted on Jan 22, 2010
SOURCE: 165,000 forced air reddy heater
It would help if I knew the model of heater because there are 2 different technologies that are used in Reddy Heaters. Having more information could affect my answer.
Generally, if a heater runs with the lid off but shuts down with the lid on, its a sign that either the air pump pressure is not to specs or the nozzle is restricted or worn out. Desa International, the manufacturer, recommends annual replacement of the nozzle, but this is arguable, depending on the age of the heater.
I am pasting a document that I've had around for awhile, that may help:
"A worn nozzle creates a spray pattern, where a good nozzle creates a fog. With a coarse spray pattern poor combustion results in an off color flame, . The photocell doesn’t like the color, sends a signal to the computer which shuts everything down. That’s the job of the electronics. On HSI heaters it is all about correct flame color , not just flame.
The part where you write "If I remove the cover again it runs fine" is a symptom of a bad, worn, or restricted nozzle. Remember- the ignitor only stays red for 5 seconds, then the flame keeps itself lit. The nozzle's pattern is a cone. Lift the lid & the pattern widens (aerodynamics) - replace the lid and the cone narrows & possibly distorts then the flame goes out.
This nozzle rule will only apply if everything is correct as far as fuel delivery applies. The pump pressure must be correct- not almost correct. Set the pressure with a low-pressure gauge that registers12-15 psi max. A gauge with a higher scale just will not read close enough to satisfy the system. If the pressure is not correct, the above rule will not apply. Instructions for setting the pressure can be viewed at http://reddyparts.com/pressure.htm.
In addition, a fan can cause the same problem if damaged or mis-matched to your specific model.
I must mention that any air leaks on the pressure side (or vacuum leaks on the fuel line, for that matter) between the pump and the nozzle will create a rich/lean mixture at the combustion chamber, creating an off-color flame."
Good luck, I hope this helps.
Posted on Dec 03, 2008
SOURCE: have a 1650000btu reddy heater.
Tue up kit from your local lawnmower supply house.
Posted on Dec 18, 2009
Jan 23, 2017 | 2007 Chevrolet Corvette Convertible
Jul 31, 2015 | GE WHRE5550K Top Load Washer
Apr 11, 2015 | Goodman CKL36AR36 Air Conditioner
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Dec 12, 2010 | All-Pro Forced Air Kerosene Space Heater...
May 27, 2010 | 1999 Volkswagen Cabrio
Feb 25, 2010 | Washing Machines
Feb 24, 2010 | BenQ PE8700 Multimedia Projector
Dec 29, 2008 | 2003 Kia Optima
Dec 13, 2008 | Reddy Heater-30-55,000 BTU Variable
Nov 09, 2008 | 2001 Ford Windstar
4,459 people viewed this question
