My hp color laserjet 5550 is not printing cyan i have replace cartrige and power supply board also disable toner check inter -change cartridge cyan now prints but nothing prints from the cyan slot
Check the black cover on the pick up assembly under the cyan cartridge. If it is only a fraction too high cyan will not print. Make sure it is clipped in place correctly.
Posted on Jul 26, 2012
SOURCE: Hp couler laserjet 2600n
There is a chip on the cartridge that is bad or missing. If this an after market cartridge this a common error with the chips. You either need to return the cartridge or find someone that sells the chips fot the cartridge.
Posted on Aug 11, 2007
SOURCE: LaserJet 3550: override chip on toner cartridge to continue print
Disable Carts is for service tech troubleshooting.
You will have to replace. All prints use all cartriges every time.
Posted on Jan 22, 2009
SOURCE: HP Color LaserJet 4500N Toner Cartridge Stuck
Hi, i have the same printer and regularly get this problem. Open the top cover and rotate the cartrige that is on top slightly backwards towards the back of the printer. Once you turn the printer on again this usually solves the problem
Posted on Aug 22, 2009
SOURCE: no power on hp color laserjet 5550
here http://www.generalmanual.com/Printers/HP-Color-LaserJet-5550dn-Printer.htm
you can download this is printer user's guide (under "download now" near the bottom of the page) help you.
Posted on Sep 10, 2009
SOURCE: HP LaserJet 5550 Dumping Excess Toner...
Are you using HP toner?
Pull out the cartridges and vacuum out the printer. Get a compressor or canned air and blow the printer out. Vacuum again,
Install HP toner and try printing again.
Posted on Mar 17, 2010
Jan 20, 2015 | HP Laserjet Cp2025n Printer
Aug 17, 2011 | HP LaserJet 5550 Printer
Jun 16, 2010 | HP Color LaserJet 2600n Printer
Jan 20, 2010 | Computers & Internet
Jan 18, 2010 | HP LaserJet 5550 Printer
Nov 14, 2009 | HP LaserJet 5550 Printer
May 01, 2009 | HP Color LaserJet 5550dn Q3715A Workgroup...
Jan 20, 2009 | HP Color LaserJet 2600n Printer
Nov 13, 2008 | HP Color LaserJet 4500n Printer
Jun 18, 2008 | HP LaserJet 4600dn Color Printer
845 people viewed this question
