Question about Metra Ford F 150 Truck 1999
Cargo Light Stays on with Door Ajar lit on dash board but all doors are shut tightly.
Posted by scriley2000 on
Anonymous
    New Friend:
Did you try replacing the door ajar switch. They cost about $15.00 from your local auto parts store. It takes about 30 min to take off the assembly and replace the switch.
Posted on Jul 26, 2010
  • Anonymous Jun 21, 2011
    I also had this problem because I lived on a dirt road, the sensors are very sensative alot of times taking a Q-tip with some baby oil and just cleaning it will do the trick, I do this about once a month because of all the dust from the dirt road and haven't had any problems since.
06 Escape the door ajar light stays on when all doors are shut...
its more then likely the wiring in the door a wire is probably broke between the door and the cab .
Jan 05, 2015 | Cars & Trucks
Cargo light stays on after car is off and door ajar light it's on when car is on.check all doors they're all close
Depending on the make model and year, it could be a sensor in one of the door latches.
Jul 27, 2013 | Cars & Trucks
Scion xb 2005 door jar light stays on & all doors are shut. How do I turn it off?
check all door switchs the most comun is the driver side maybe is fail or disconected and fuses too,
Jul 22, 2012 | 2005 Scion xB
Doorajar liht and beeper sounds
It can be issue with faulty sensor or a wiring issue.Troubleshooting is required.
Click the help link shown below:---
Door Ajar Light and Dome Light Remains ON? http://whoisbyme.blogspot.in/2012/06/2003-mercury-sable-door-ajar-light-and.html
Door ajar light stays on? http://technoanswers.blogspot.com/2012/01/door-ajar-light-stays-on.html
Thanks.
Jun 26, 2012 | 2002 Ford Explorer
Doors are shut close and interior lights stays on
The tiny door "ajar" micro switch that senses the door position (open or closed) is a real problem in these years of all Fords, the switch is twisted into the door latch inside the door, there are 2 switches in the rear tailgate and one for each front door and then a contact switch plate for the side cargo door ( a different design). To replace all these switches is quite a job, but hold on, the dealer can scan the system with a special tool that reads the switch position, with this he can see exactly which switch is the problem, this aves time and money in the long of it. Many independent shops have a similar tool as well that can read the switch position.
Dec 07, 2011 | 1998 Ford Windstar
Door adjar warning light stays on. Dome and cargo light stays on.
You need to remove the door ajar sensors from the doors and clean and lube them. You must remove the interior door panel then remove the door latch. Then twist the switch out of the latch to work on it.
Mar 19, 2010 | 1997 Ford F150 Regular Cab
Door ajar light stays lit when all doors are shut 2005 GMC Canyon
This seems that either of the door switches is/are faulty. Try pushing the switches fully on each plunger switch on each door individually, keeping the other doors closed while you do. See if one of them causes the light to go out. If you do find one turns the light off, it's an adjustment problem with the plunger switch. May still need to be replaced if it won't depress enough with the door closing to turn off.Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Feb 17, 2010 | 2004 GMC Canyon
Rear access door ajar
What's your question ? Tailgate ajar light lit on the instrument cluster ?
The Body Control Module (BCM) monitors the lift glass and the cargo door ajar switches. When the switch closes, the path to ground is completed, and the BCM sends a class 2 message to the instrument cluster to display the CARGO DOOR AJAR message.There are two ajar switches for the rear door ,a left an a right ,the third switch is for the lift glass ajar switch . All three of these switches splice pack SP410 At ground point G410
(Shouldn't have any readings when door(s) and/or window closed.) It's the opposite . switches are open with door closed , G410
In the Body Harness, Behind the RR quarter trim panel near the D-Pillar
It turns out it has nothing to do with rear door. Something about drivers door actuator. NO IT DOESN"T !!!!
Nov 09, 2017 | 2003 GMC Yukon XL
Door ajar dash trouble and dome light stays on even if all doors
The door sensors will need to be replaced. A screws can be removed and then a wire can be taken of and you then can replace the switch.
Sep 25, 2009 | 2001 Ford F250 Super Duty Super Cab
2005 f150 "Door Ajar Light Always On.. Even with all doors shut..
What happens when you remove both switches, and wires? What happens when you use a jumper wire acros both wires, on both doors?
Feb 25, 2009 | 2005 Ford F-150
Metra Ford F 150 Truck 1999 Logo
301 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
jdthefixer
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
