Question about Zebra Z4Mplus Label Printer
How do i find the IP address on a Zebra Z4MPlus?
Posted by willie_simps on
Anonymous
    Scholar:
  • 31 Answers
If you can not see it in the LCD menu on the front panel, you can find it by printing the IP info on a label. There is a reset button near the Ethernet jack that will let you reset the print server settings or allow you to print a config label. Load up some media, power the printer on. Once the printer is fully booted, use a paper clip or the like to press the button once. A label will print that details the IP settings. Once you have the IP settings, you can log into the printers web interface by typing the IP address in your browsers URL bar. Do get a copy of the manual.
Posted on Jan 30, 2010
1 Related Answer
Anonymous
SOURCE: Zebra Z4MPlus Ribbon Wrinkles
I changed the print head, and the issue was solved.
Posted on Aug 04, 2008
Zebra z4mplus blanck screen
Sounds like the main board needs replacing. Google '77904m PWB" and you will get a place to buy the part. However you mentioned the IP the Z4m does not have an Ethernet option so make sure that it isn't a Z4m+.
Mar 26, 2015 | Zebra Z4Mplus Label Printer
No detecta el zebra net
Laura: cuando conectas un zebra net a una impresora zebra, se habilitan en el setup las opciones de red, como lo es la IP, GATEWAY, etc, y asi sabras que el zebra net se ha reconocido.
Roberto Martinez
Mexico
[email protected]
Jul 25, 2011 | Zebra Z4Mplus Label Printer
I just bought a used Z4Mplus printer, I need an illustration/drawing to show me how to install the ribbons? Thanks.
Goto http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html and then ctrl+f paste Z4Mplus in the Find: slot.
You will find (Z4Mplus & Z6Mplus Users Guide 13163L-002 Rev A (en)). Next column: 13163L-002 Rev. A, next column: User Guide next column: English last colum: Download. The download is a 171 page manual.
Jun 01, 2011 | Zebra Z4Mplus Label Printer
We need to get to ip protocol
to have access to network setings, need to connecto with the cabel firs, then if connect, the setings apear from the setings (IP , Gateway, subnet mask.)
Mar 11, 2011 | Zebra Z4Mplus Label Printer
How do I get the Network Configuration to print on a Z4MPlus- Thanks
this feature just appear in the setings if some network cable is connect. if have connectivety, go througth the setings and see IP adress/subnet mask, gateway, and can configurate properly (permanent or DHCP.
Dec 20, 2010 | Zebra Z4Mplus Label Printer
I nstalled Zebra Z4Mplus printer drivers. is it supports to ZEBRA ZBR2303372 drivers?
shivacando: You can use the "zebra universal driver", the "zebra designer driver" from Zebra Technologies and also the "seagull driver" from Seagull Scientific Systems.
Roberto Martinez
[email protected]
Dec 15, 2010 | Zebra Z4Mplus Label Printer
Labels feeding incorrectly on Z4Mplus Zebra priner
Use this link and download the quick setup guide. Page 4 shows how to properly load the labels.
Aug 10, 2010 | Zebra Z4Mplus Label Printer
How do you set a static IP address on the Zebra 4Mplus printer?
If this is a wireless printer then all you need to do is set an address reservation on your router and then set up a fixed IP port on your printer driver.
First: Install the printer driver as a normal USB printer by connecting the cable during the install process dont use the wizard if you can help it.
Second : Find your MAC address for the printer (all types of Network Cards MUST have one) this will either be in the LCD control panel or on the bottom of the printer on a label and set this in your admin panel of your router to say 192.168.0.10 for example. You can normally enter this using 192.168.0.1 but all routers are different. Check here for your make and model http://www.routerpasswords.com/
Last : Goto the printer driver properties for the USB printer you have just install click the port tab and click add standard IP port as shown below, then disconnect the USB lead this is only required to make sure the correct inf file is used on the driver install.
Thats is. !!!
Nov 30, 2009 | Zebra Z4Mplus Label Printer
Zebra Z4m w/print server II has Netware enable, How do I turn it
The print server has a web access if you know the IP address. You may need to have a Username (root) and password to gain access to what you wish to change.
Apr 02, 2009 | Zebra Z4Mplus Label Printer
Aug 01, 2008 | Zebra Z4Mplus Label Printer
Zebra Z4Mplus Label Printer Logo
4,134 people viewed this question
Top Zebra Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
