This means the signin API is locked into the bridge.
You need to run "clearapi" to clear the hung api connectin slot.
Login with dcbguest , navigate to /usr/dcb/bin
use "dumpapi" to list the active signins along with api slot.
Then use "clearapi" to clear the respective api slot.
This will fix your problem without reinitializing the bridge.
Once you have all the wireless
settings of the router, you are ready to connect the play station or the
x-box to the wireless network.
Play Station
Now go to the settings page of the PLAY STATION
NETWORK SETTINGS ==>
INTERNET CONNECTION SETTINGS ==>
WIRELESS SETTINGS ==>
If you get confirmation screen displayed stating that you will be
disconnected from the Internet. click YES ==>
select EASY ==>
select WIRELESS ==>
SCAN ==>
you will
see your SSID ( wireless network name)==>
select the
security settings ( router wireless settings)==>
enter the KEY ==>
select the IP address settings EASY ==>
save your settings ==>
Test the
connection .
