Question about Minolta magicolor 2300W Laser Printer
If you can not rotate the toners by using the DISPLAY MENU,
You can rotate them MANUALLY, using a flat head screwdriver or even a key for your car or front door.
Open Front Cover/Door of Printer
Remove Waste Toner Box
Where you see the side of the Blue Cartridge, look to the LEFT and locate a small rectangle with a circle inside it.
Push your car key or flat head screwdriver into this rectangle and the circle will push back and release the lock on the cartridge, holding in with one hand and turning cartridge with the other hand until you get the cartridge you want to replace.
Remove the screwdriver / car key and pull out the empty cartridge and replace with new one.
Replace Waste Toner Box, close front cover/door, switch on and the printer will rotate back itself to it's normally position...... JOB DONE
Posted on Mar 13, 2011
Feb 19, 2015 | Ricoh Office Equipment & Supplies
May 24, 2012 | Toshiba e-Studio 232 Black and White...
Nov 08, 2009 | Lexmark C540N PROD SPECS TBD Printer
Jul 25, 2009 | Samsung CLX-2160N All-In-One Printer
Apr 20, 2009 | Toshiba E-Studio 3511 Color Copier
Mar 03, 2009 | Epson Aculaser C1100 Printer
Nov 07, 2008 | Dell 3100cn Laser Printer
Jul 14, 2008 | Office Equipment & Supplies
Apr 26, 2008 | Epson Aculaser C1100 Printer
Nov 17, 2007 | Konica Minolta DiALTA CF910 Copier
82 people viewed this question
