Canon Imagerunner C3200
Error Code E000001-0004
Had moisture damage. Wondering where to start with repair. This is all that comes up on screen
The main thermistor TH1 has poor contact or open circuit.The thermal switch TP1 has an open circuit.The fixing heater has an open circuit.The SSR is faulty or the DC controller PCB.After the main power switch is turned ON the temperature detected by the main thermistor does not reach 70 C.The error must be reset in service mode :COPIER - FUNCTION - CLEAR - ERR
E000 Low fuser temperature. Heat lamp, thermoswitch, thermofuse, thermistor, SSR E001 High fuser temperature. Thermistor, SSR, pinched wire E002 Low fuser temperature. Same as E002 E003 Same as E000/E001 E010 Same as E002 E022 Motor drive problem E030 Counter E202 Scan motor, sensor E204 Scan motor, sensor E210 Lens motor, sensor E220 Exposure lamp E240 DC controller (main board) E401 Pickup drive problem (might be Doc. Feeder) E402 Document belt drive problem E404 Exit motor (document feeder) E411 Document sensor (document feeder) E500 Sorter/machine communication problem
