Question about Canon Speedlite 430EX TTL Flash
My 430 is making a buzzing noise then it flickers
My 430EX is making a buzzing noise then it flickers in between taking images. The images are still OK, but I can't tell if it's the flash or the camera which is new. 50D
Posted by scscom8 on
hmlee390
  • 736 Answers
The buzzing noise is normal for that model .. first it makes noise as it charges and maintains the capacitor then when it auto focuses ..
here is a discussion of your speedlite model and the buzzing it produces
http://www.cameralabs.com/forum/viewtopic.php?t=19864&sid=ed65281bc80849c5fa34264a56c5f9f4
Posted on Jan 19, 2010
Vizio gv47l
The problem is with your IP (inverter / power) board. This is a pretty common issue, actually... one I see almost daily. The power board for your TV is part number 0500-0507-0260, but they're not available anymore... the sub part is 0500-0507-0260R.
Jan 17, 2014 | Televison & Video
Canon 430ex ii seems to flicker rapidly sometimes before taking pictures
Yes it is. The system is simply measuring the flash to meter the exposure.
Dec 29, 2013 | Canon Speedlite 430EX TTL Flash
Just got a Canon 7D. Attached my 430EX to the hot shoe and it won't fire. Tried new batteries and checked the contacts, and it still won't work. Put th 430EX back onto my Rebel XTI, where it has always...
Make sure you using flash grade batteries and not rechargables. try energiser ultra or litiums or duracelll plus but nothing else. if the charge light is not coming up then most likely batteries. I would take it to your local camera shot and test your 7d with one of thier 430 just to make sure the hotshoe didnt short out the flashgun
Feb 21, 2011 | Canon Speedlite 430EX TTL Flash
Samsung HL-P4663W/HL is making a buzzing noise
Color wheel needs replacement is the most likeliest cause.
Jan 02, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
430EX won't fire.
Can you short the pins to have the flash [email protected]
May 27, 2009 | Canon Speedlite 430EX TTL Flash
Canon 430 flash
the best will be to take the flash to a canon repair center
you can try to repair it yourself, you will need a peace like this:
http://cgi.ebay.com/CANON-420EX-430EX-580EX-HOT-SHOE-FOOT-LOWEST-INTL-SHIP_W0QQitemZ370071354531QQcmdZViewItem?_trksid=p3286.m20.l1116
Sep 09, 2008 | Canon Speedlite 430EX TTL Flash
Replacing widepanel screen on Canon 430 EX flash
If you need this repaired I can do this . The price is $108.00 includes shipping .
Berrie Smith Camera Repair [email protected]
Jun 23, 2008 | Canon Speedlite 430EX TTL Flash
Constant flickering
This could be early signs of imminent failure of a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Dec 28, 2007 | Canon PowerShot A85 Digital Camera
Canon Speedlite 580EX
if u set the 580ex on master and the 430 EX on slave it works :) u dont need STE2 for this simple task.
Oct 18, 2007 | Canon SPEEDLITE 580EX TTL Flash
Canon Speedlite 430EX TTL Flash Logo
864 people viewed this question
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Paul Green
Are you a Canon Camera Expert? Answer questions, earn points and help others
