Question about Kodak EASYSHARE G610 Thermal Printer
Cant pick up paper
I have correct paper in tray but printer will not pick it up and on the rare occasion it does it tells me its the wrong paper which it isnt. its a kodak g610 printer using kodak extralife paper as supplied with the printer. its just over a year old and is as far as im aware otherwise in mint condition. we have maybe printer 160 photo's with it
Thanks in advance for your help
Posted by sarandmal on
Anonymous
    New Friend:
The dock will not pick up paper lost my manual i tried one piece half full tray and afull tray it worked last time i printed what up
it keeps saing its out of paper
Posted on Jul 20, 2010
Unable to pick up papaer on tray 2 error 13.00
common faults for poor feeding on lj5200
1, feed rollers are worn - replace
2, sep pad is worn ( cant seperate pages correctly)- replace
3, paper empty tray sensor actuator arm snapped - unable to raise cassettetray- replace arm
4. paper feed roller fail to turn- feed unit clutch assy faulty- replace feed asseembly
5.paper tray pass guide out of position (blocking feed path) - pin that holds in place has snapped- replace feed assembly
Dec 13, 2013 | HP LaserJet 5200 Printer
Printer i making a weird clicking sound. It won't print. It has error light On. Status: load tray 1 / Plain letter Toner level is 80%
check if there is a paper at tray 1. if so, may be the printer is unable to pick up paper due pick-up roller problem. try to remove the tray and look in the middle, there should be a rubber like roller. if its too glossy it cant pick the paper.
Sep 18, 2011 | Dell 1720dn Laser Printer
I AM USING HP LASERJET PRINTER 2300dn and im experiencing jam, what is wrong with the tray?
I think it not the paper tray. It is the paper pick-up roller. When the rollers get dirty or worn-out, the printer fails to pick the paper, which results in paper jam. So, remove the paper tray and toner cartridge and locate the paper pick up roller in the middle. Clean it with luke-water and lint-free cloth. I hope this would fix the issue
Hope this helps! Good Luck!
CreativeTECH
Jan 07, 2011 | HP LaserJet 2300dn Printer
My printer, HP injet 1410, could not pick up the paper. Can you tell me what the problem is.
I assume the printer is making noises and moving, TRYING to pick up the paper...
If so, there are 3 possible issues:
1) you have too liittle paper in the paper tray. Add more paper so that the tray is full to around 3/4, not less.
2) You may have too much paper on the tray. Remove some paper from the tray untill the tray is around 3/4 full, not more
3) The rubber rolls that pick up the paper may be dirty with paper dust or dirt. Put 2 drops of alcohol on q-tip and carefully clean them. Let dry 30 mins. before trying to use the printer.
Mar 26, 2010 | HP PSC 1410 All-In-One InkJet Printer
Paper jam from tray 1
If the paper jammed occasionally, it might be your pick up roller.
Jan 20, 2010 | Office Equipment & Supplies
Printer picking wrong tray for print
From the start menue to printers and faxes go to your printer right click and select properties label the 4 drawers as to paper type and select continue, or auto continue to off.
-Carl, please let me know if this helps.
Jun 26, 2009 | Xerox Phaser 8560MFP Laser Printer
My hp printer is telling me that i need to add
Not sure what printer you have but most consumer models don't actually detect paper in the tray. These machines will give an out of paper error if the paper is not picked up from the tray.
If the machine sounds like it is trying to pick up the paper but giving the error check and clean the pick up roller and look for something blocking the paper path.
hope this helps
Mar 15, 2009 | HP Office Equipment & Supplies
Lexmark T630 printer pulls paper from wrong tray
Verify your settings under the Paper Menu are correct as far as size and type. All trays with same size and type settings are automatically linked as per the User Guide.
Dec 31, 2008 | Lexmark T630 Laser Printer
Printer purchased 15/5/08 on trying to set up red light continues to flash so unable to print and proceed the screen only shows the language selected and fails to move on
Usually printers like to flash red under the following conditions:
1. Paper jam. So be absolutely sure there is no paper stuck in there, or that a piece of paper is not partially fed too far for the printer to pick it up as a new piece.
2. Out of paper, speaks for itself.
3. Wrong paper tray selected. i.e. you install the printer using default settings, but somehow, the printer is expecting to 'see' paper via an alternate input / tray. Check the printer settings to see if the paper tray matches the tray you are feeding paper too.
This one has caught me out many times.
Hope that helps.
May 16, 2008 | HP Office Equipment & Supplies
No Paper Pickup error
Check all this ---------
1.check the paper pickup roller may be its not functioning
proper.
2.check the paper pickup sensor(clean this)
3.check the paper pickup tray for proper work.
4.check the gear of paper pickup.
thanks
Mar 20, 2008 | HP LaserJet 3390 All-in-One Multifunction...
Kodak EASYSHARE G610 Thermal Printer Logo
265 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Ekse
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
