Tip & How-To about Office Equipment & Supplies
Canon 8530 E000 The surface temperature of the fixing assembly upper roller fails to rise by a specified value within 90 sec after power-on. The surface temperature of the fixing assembly upper roller fails to reach 150 C within 8 min after power -on. The surface temperature of the fixing assembly upper roller fails to reach 180 C within 5 min after it has reached 150 C. The surface temperature of the fixing assembly upper roller falls below 50 C in standby. E001 The surface temperature of the fixing assembly upper roller exceeds 250 C. E005 The cleaning belt inside the fixing assembly has been taken up more than a specified length. E010 After generation of the main motor drive signal, two or more pulses are not received within 2 sec. E020 The accumulative time during which the toner supply signal (TSP) has been generated by the developing assembly reaches 3 min. E050 The holding tray home position signal (THP) is not generated within 4 sec while the holding tray motor drive signal (TMDP1,2) is being generated. The holding tray home position signal (THP) is generated 1 sec or more while the holding tray motor drive signal (TMDP1.2) is being generated. E13 The error detection circuit on the waste toner feed motor driver PCB has detected on overcurrent. E203 Input of two or more clock pulses is not received within 2 sec from the scanner motor drive signal is generated. E210 The lens home position signal (LHP) is not generated within 4.8 sec after the power switch or door switch has gone ON. The lens home position signal (LHP) is generate 2 sec or more. E240 An error has occurred in the microprocessor on the DC controller PCB. E243 An error has occurred in the communication between the microprocessor of the DC controller PCB and the microprocessor in the control panel. E710 An error has occurred in the communication between the DC controller PCB and the controller PCB of the option, and the DC controller has detected the error.
