Tip & How-To about Office Equipment & Supplies
Canon 6035 E000 Fuser did not heat up. Lamp, thermal switch, thermistors, connections, AC driver, DC controller, SSR, etc. E001 Fuser temperature too high. Same possibilities as E000, as well as shorted wire. E002 Fuser temperature not rising at correct pace. Same possibilities as E000 E003 Fuser temperature drops. Same as E003. E004 Fuser problem. AC driver, SSR bad, wire shorted. E010 Drive problem. Main motor, gears, etc. E030 Total counter. E064 Composite power board or DC controller. E065 Composite power board or DC controller. E202 Scan motor or scan sensor problem. Panel locked with no code. Scan motor problem. E203 Scan problem or scan sensor. E204 Scan problem or scan sensor. E210 Lens sensor or motor problem. E212 Lens sensor or motor problem. E220 Exposure lamp or exposure lamp regulator board. E224 Blanking shutter motor or sensor. E240 DC controller or composite power supply problem. E244 DC controller. E400 RDF to copier communication problem. E401 RDF Pickup motor or pick up sensor. E403 RDF feed motor or pulse sensor. E404 RDF delivery motion problem. E404 RDF delivery motor problem. E411 RDF tray sensor or registration sensor. E500 Sorter main board or communication with copier. E510 Sorter feed motor. E530 Sorter guide bar motor. E531 Sorter stapler motor. E540 Sorter bin shift motor. E541 Sorter bin motor. E550 Sorter power supply. E710 DC controller
