You can download the manual from here: http://www.weller-toolsus.com/MagentoShare/media/mannuals/WES51_OI_PL.pdf
Also, if you buy tips get them from Weller. I bought an off brand tip, it seemed like it fit, but not tight enough and it would not transfer the heat and I could not solder with it.
I thought the station was defective but not so. It was just the imitation tip that I bought.
The fake tip was tight,
But still would not get hot enough to work correctly.
SOURCE: Hi!
Bill, i would use a connector with the correct number of ends made for a radio. you could probally find them at radio shack. be sure to connect the right wire to the right pin on each. you would need male and female. then the next question is yes four screws under the rubber feet
SOURCE: I have a Weller 1002B soldering station. Haven't
Hi, I'm not sure the tip is defective. Check that the tip is screwed in tight. If it is not good and tight the tip will not get a good heat transfer from the solder wand. Hope this helps. If the wand will heat then the tip should.
