To check ice makers in general you have to first check there is water which is simply filling a glass from the freezer door dispenser. Next you need to check there is not a frozen fill tube where the water is run through the cabinet into the ice maker.(you should be able to blow through it from the back when you disconnect the line) If it has frozen solid with water, this has to be cleaned of the ice(melted with a hair dryer) Frozen fill tube problem usually caused by water valve not completely shutting off-a drip) May work ok with old valve for a while without replacing also.
The next is to test water valve and ice maker by jumping the thermostat inside the icemaker assembly, there are pins under the cover of the ice maker. If you are this far also check for 120 volts at ice maker. This is general, if you have a ice bin in the door, you have a emitter receiver board which needs to be jumped out. It can get complicated, but you are trying to break down the system components to isolate the problem.
Also remember ice makers generally have a thermostat in them to prevent operation if not down in the zero to fifteen degree range. You can get one of those outdoor liquid filled mercury or alcohol stemmed thermometers to test your freezer temperature before you tear apart your fridge..........
Ice maker stopped making
ice. For this problem you have check few things. First thing, is the water
filling in the ice maker chamber and then ice maker not making ice? Or, the
water is not filling in the ice maker chamber so it's not making ice. If the
water is not filling in the ice maker chamber then it's clear that ice is not
getting made due to no water in the chamber. For no water filling, the problem
is either water supply valve turned off so water is not filling. Turn on the
water supply and it will fill. But if the water supply is turned on then the
other possibility is ice blockage in the water fill tube. There is a tube from
which the water runs and enters the ice maker chamber. If this tube is blocked
then water will not enter the chamber. The tube needs to be defrosted, by using
hair dryer. This procedure melts the ice collected in
the tube and water starts running again. But if water fill
tube is completely clear and no ice blockage or any other blockage. Then other
possibility is water valve at the back of ice maker unit. This water valve is
for letting the water in the ice maker. The water valve open only for
7 seconds and in this time the water fills in the ice maker chamber and then
water valve closes and the same procedure runs again in the next
water filling cycle.------- For your information I will mention that there are
two valves. One is the main valve the back of the fridge section. This main
valve lets the water enter the refrigerator and other valve is at the back
of ice-maker section. This other valve lets the water to enter the
ice maker. In most of the cases the fault is water valve at the back of ice
maker section. ------------- The other above possibilities which I gave you is
water not filling in ice-maker chamber so it's not making ice. But
now consider that water is filling in ice maker chamber but it's
still not making ice. Then the problem is ice maker unit itself. This unit is
controlled by main board. But in most cases if water is filling the ice maker
but it's not making ice then its faulty ice maker unit. So see if the problem
is water not entering the ice maker then the water fill tube is frosted by ice
or the water valve at the back of ice maker is faulty. Replace the valve.
You can get required
parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks.
Helpmech.
