Maybe your files are'hidden' ??! Enable to view hidden files by:
SOURCE: How do I repair corrupted files ?
You can run scandisk on that drive and see if it repairs the index.
Go to my computer move the mouse to the drive.
Press the right mouse button.
Press properties.
Select the tools tab
Select error checking.
If that doesn't work you should check to see if something is going on with the power supply or the drive itself.
SOURCE: The file system of my hard drive become RAW.
http://www.z-a-recovery.com/unformat-tutorial.htm
This tutorial describes the procedure to recover one volume when
The recovery is done in seven steps, requiring about eleven (11) mouse clicks.
Note: The older than current versions of ZAR might have been used to create the screenshots in this tutorial. We did not update the screenshots if there is no significant difference between older and current versions. If you see some option in the program which is not described in the tutorial, just leave it at its default setting.
Step 1 - Get, install, and start ZAR
Download and install ZAR just like you do with any regular program.
When you run it, ZAR displays the window like the one below:
Step 2 - Select processing mode
Step 3 - Select physical device to recover
SOURCE: My Book (G:) icon is different
no you there iss no big problem.
The icon of your hdd iss created from the autorun.inf
http://www.fiveanddime.net/notes/hd-icons.html
Change hard drive icons
Change hard drive icons:
To change the icon for your hard drive, create the
following file in notepad:
[autorun]
icon=C:\WINDOWS\SYSTEM\Pifmgr.dll,36
Notice it's two lines.
If your hard drive is C:
click Save As... and navigate to C:
and save it as autorun.inf
enclose it in quotes so Notepad won't put a .txt
on the end of it
The path specified is the typical Windows path
yours may vary, but you'll have that dll file.
The 36 at the end is the number of the icon I chose.
(Icons in a file are numbered, starting at 0.)
To see the change, open Windows Explorer; click
F5 if needed to refresh.
To preview your icon options, select an icon on
your desktop, right-click and select
Properties, then Change Icon. You can also select
any other .dll file in your computer, although most
won't have icons.
The common Windows icons are in
C:\Windows\System\shell32.dll
(xp = C:\Windows\System32\shell32.dll)
You can also point to a single icon.
Using the example above:
[autorun]
icon=c:\windows\cursors\myicon.ico
I have three hard drives and nine partitions; under
WinMe, I had to move the icon/dll to each
partition and edit the autorun.ini, i.e.
C:\Windows\System\Pifmgr.dll,32 became Pifmgr.dll,32.
WinMe also wouldn't let me change the icons
for the primary partitions of the first two
drives, but did let me change the
primary partition icon of the third drive.
SOURCE: wd problems
Change the drive letters, worked for me. I have 2 WD My Books, I made one R: and one S: worked fine after that. On vista go to Control Panel -> Classic View -> Admin Tools -> Computer Management -> Disk Management -> Right click on WD drive and change letter. For some reason G, F, E, ect seem to run into some problems
SOURCE: doesn't show any files and folders when drive opened
Congrats, You got a nice virus. Its better you backup your drivers and data from ur root partition format it. reinstall your operating system and install avg 8.5 before browsing any of the other partition. I can surely tell u your task manager, registry editor or show hide folder won't be working. There is no permanent solution to this other than format. But beware don't browse other partition before installing avg 8.5. Your earlier installed antivir has given its way to virus its of no use. You won't be able to install antivirus or visit any malware removal virus site. welcome back.
If these steps do not correct the problem, you will need to re-format your External Hard Drive ***WARNING*** FORMATTING A HARD DRIVE WILL ERASE, YOU WILL LOSE, ALL DATA
