Question about HP Photosmart C6180 All-In-One InkJet Printer
Changed all the ink - all new - still makes a rachet sound and shows Error Oxc18a0106 - will not print - what do we do now to have it print
Posted by gstembor on
Anonymous
  • 33 Answers
Issue The product displays an '0x ... ' error message. The exact text of these error message varies by product, but it is usually preceded by the word 'Error .' If your error message includes the words 'ink system failure ,' and you use cartridges 564, 364, 178, 862, or 920, please refer to 'Ink System Failure' Message Displays on the Control Panel Common '0x...' error codes
  • 0xc18a0201
  • 0xc18a0206
  • 0xc18a0306
  • 0xc18a030a
  • 0xd0620130
  • 0x887dd03a
  • 0xd05d010d
  • 0xf0af8004
  • 0xc19ac3ff
  • 0xc18a050a
These error codes indicate that the product has an internal error condition. Solution one: Reset the product
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (Changed all the ink - all new - still makes a - c01424575.gif ). Figure 1: Example USB connection (your product might not look exactly the same as this example)
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Posted on Jan 19, 2010
How to fix HP photosmart 3310 printer Error:Oxc18a0106
someone else's answer:
If you get an error message on your printer screen (HP Photosmart C5180) which says " 0xc18a0106 ink system failed ", you'll need to carry out a Master Reset on the printer.
Something usually causes the error to occur and this is usually a failed microchip, out of date chip or interruption when installing a new cartridge and this will have to be rectified before continuing. Most problems are usually from the last cartridge inserted, so start by replacing that cartridge. You will also need to have all cartridges with some ink in them or you'll need to replace any empty ones before continuing. Once the problem cartridge has been replaced, keep it as it may still be ok to use at a later date once the error has been reset.
To reset the printer:
1- Unplug the USB cable from the printer.
2- Press the On/Off button to turn off the printer, unplug the power lead from the printer, press and hold both the "OK" button and the "HELP" button, then plug in the power lead, wait a few seconds and release the two buttons, then press the "On" button.
Your printer will now initialise and you'll need to follow the on-screen instructions and choices on the printer. This may take several minutes to complete. Your error code should now have disappeared and you will now be able to Copy and Print.
3- Replug the USB cable from the printer.
Aug 18, 2014 | HP Photosmart 3310 All-in-One Printer...
How do I fix ink system failure error message on a hp photosmart c8180 even though I have replaced all cartridges. Need to rest the system any ideas?
i love google.... usually:
http://h30434.www3.hp.com/t5/Other-Printing-Questions/Photosmart-C8180-Ink-System-Failure-Error-0xc-18a0005/td-p/331285
If you need further help, I’m available over the phone at https://www.6ya.com/expert/robert_beef7390c57fac0d
Jun 24, 2014 | United Stationers HP Photosmart C8180...
It won"t print ,error oxc18a0106
Hope this helps.
Solution:
Step one: Reset the printer
Press the On button to turn off the printer.
Unplug the power cord and universal serial bus (USB) cable from the back of the printer.
Wait 30 seconds.
Plug the power cord back into the printer.
Press the On button to turn the printer on.
If Ink system failure does not display, the issue is resolved; reconnect the USB cable and resume using the printer.
If the previous steps have not cleared the message, continue to the next step.
Step two: Download and install firmware update
Go to the product support page to download the update.
http://h10025.www1.hp.com/ewfrf/wc/softw...
Click Software & driver downloads.
Click on the appropriate operating system link.
Click on the Recommended update to fix long power-on cycle and ink system failures link and follow the instructions to download the file.
After downloading is complete, disconnect all other USB devices from the PC. Make sure the product is powered ON and plugged into the USB port.
With the printer directly connected to the PC, click the downloaded file FirmwareEnable_Release.EXE.
Click Open/Run.
Click OK at the Update successful window. The error should have been cleared from the printer display.
Jan 06, 2011 | HP Photosmart C6100 All-In-One Printer
Cannot print . Ink system has failed. Unable to copy, receive faxes, or print. Error:Oxc18a0106
Try the following steps to remove HP Printer Error Code 0xc18a0001 :
1. Without turning off the printer, unplug the USB cable.
2. Remove the cartridges.
3. Wait until the message "Insert cartridge" appears.
4. Unplug the power cord.
5. Wait 60 seconds.
6. Reconnect the power cable. If the printer does not turn on automatically, press "On button".
7. Reinsert the cartridges and close the lid.
8. If the printer has a page of calibration accept.
9. Reconnect the USB cable and remake an impression.
10. If the problem persists, the machine must be repaired.
Jul 22, 2010 | HP Photosmart 3310 Printer
Error oxc18a0106 ink system has failed, unable to copy receive faxes or print.
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide to purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com , click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 07, 2010 | HP Photosmart C6180 All-In-One InkJet...
Says:ink system failed,unable to copy,fax,print error code Oxc18a0106
It means you are out of ink and on newer printers, it can be only one color that will cause ink failure.Check your ink levels and replace the color that is empty.
Oct 26, 2009 | HP Photosmart C6180 All-In-One InkJet...
Have changed Ink Black and Colour... Stil getting error Message.
Make sure the tape covering the hole on the bottom of the black cartridge is removed. and then go into the printers folder and right click on your printer icon and go into the properties of that printer and there should be something in there to tell it that you changed cartridges and you can also print a test page as well.
Feb 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
F380 deskjet - error - refuses to pront
I have this printer with the same problem , worked fine for 1 year, printed over 1600 pages total ( according to the built in HP program that records how many pages I printed and how many times I used the printer) then it stopped printing. The ink cartridges are new, the software is fine, and it says ink levels are good. It physically goes through the motions of printing, loads the paper, makes all the normal sounds it used to and pushes out the paper when it's done - but the page is blank. I did some surfing and read some info that some HP printers are pre-programmed to stop certain functions so you buy a new printer. I know that might sound crazy. How long have you had the printer and how many pages do you think you printed?
Nov 09, 2008 | HP DeskJet F380 All-In-One Printer
Hp 3210
Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Apr 16, 2008 | HP Photosmart 3210 Printer
Error A1
This is no error! It indicates that the scanner is open (what you have done to replace the carts or when there is a paperjam).
It might be that the ph is clogged (mostly due to generic ink).
Run the manual cleaning procedure 3 times!
If there is no more bk /y you need a new ph.
Mar 27, 2008 | Brother DCP-110C All-In-One InkJet Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
304 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
