I need a new cable assembly for my Myron and Davis ANS178 flip-down LCD monitor. It is frayed and intermittent. Is one available, or do I need to troubleshoot and rebuild this one?
Myron & Davis wireless headphones are likely designed to be used as Bluetooth headphones. They can sync or pair with Bluetooth-enabled devices such as smartphones, tablets, computers, or other compatible devices.
To use the headphones, follow these general steps:
Turn on the wireless headphones and put them in pairing mode. This may involve holding down a button or following specific instructions provided in the user manual.
On your Bluetooth-enabled device, enable Bluetooth in the settings and search for nearby devices.
When you see the Myron & Davis headphones appear in the list of available devices, select them to initiate the pairing process.
Once the pairing is successful, you should be able to use the wireless headphones to listen to audio from your connected device.
Keep in mind that the exact pairing process and features may vary depending on the specific model of Myron & Davis wireless headphones you have. If you have the user manual that came with the headphones, it's a good idea to refer to it for detailed instructions. Otherwise, you can try searching online for the manual or contact the manufacturer's customer support for assistance.
This is for those who are struggling to connect rca cables to tv. Cables are normally color coded, yellow is for video (out from dvd snd in to the tv). Red and black sometimes white is for audio (left and right). Same thing here out from dvd in to the tv.
Do you have a manual with your Car Monitor? If you do there will be the frequency that it uses to transmit to your car stereo, probably listed under the audio or setup section. If you don't I suggest that you call Myron & Davis on 909-796-3199 and tell them your model and your problem, they will be able to tell you what frequency you need to set your radio to. You can also email them [email protected]. Their website is here if you have any other issues.
It could be a game console connection problem, make sure that your Yello RCA output is going in your Video input on the monitor or monitor receiver. You might have a power or voltage problem, if the wrong current or voltage is incorrect then errors and freeze ups can happen, the player wont support the wrong voltage going in. Check your power connections, Video out/input connections and check your voltages.
Good luck.
Make sure to vote and rate me if I helped you. thanks
