Well...this solution may be a few years late for the original poster, but I did figure it out on mine. If it's the same clock that sits on a rubber stand and you press the top edge back to activate the light, to toggle between 12 hour and 24 hour clock, you press the + and - buttons, simultaneously, for 3 seconds.
I tried to search for instructions on the web but have not been successful so far. Wonder what is the base make of the clock which georg jenson use. I would not think they manufacture their own stuff.
Can you try to reset the clock, ie, take battery out and put back in.
Does the default still come as 24 hour? Does it except alarm setting in 24 hour format?
I will try to find the instructions at a local shop in the meantime.
Not sure if you responded to my comments on your problem.
It is bit unfair to rate the solution when I had tried to suggest some tests whilst I was trying to locate some instructions on this clock. I have not given you a solution yet.
Have the same clock. Just hold the "+" button a few seconds and PM sign shows. .... My question is: how do i set the clock?
If you go into the main menu under "initial settings" there should be the option to reset the 24/12 clock. Thank you, Dana
The WAVE OK indicator and the Tower Icon on the display will show if the time signal is successfully received or after manually pressing the SET/WAVE button
You can trigger a Signal Receive operation at any time by pressing the SET/WAVE button, which will activate the Signal Search function of the unit.
To Manually Set the Clock
To Set the Year and Date
1. Press SET/WAVE button after setting TIME ZONE and DST
2. Press + or - button sequentially to set the year (holding down the button will change the year at a high speed)
3. Press SET/WAVE button to confirm the year set and start the date process
4. Press + or - button sequentially to set the current date (holding down the button will change the date at a high speed)
NOTE: The weekday changes automatically depending on the year and date
To Set the Time
1. Press the SET/WAVE button after setting the calendar
2. Press + or - button sequentially to set the minutes (holding down the button will change the year at a high speed)
NOTE: Once you the press + or - button, the seconds will reset to 00
To set the 12/24 HR mode and the Temperature Mode
1. Press SET/WAVE button after setting the time
2. Press the + button to toggle between between 12HR and 24HR (military) modes
3. Press the - button to toggle between C and F temperature display mode
4. Press SET/WAVE button to confirm and quit the set mode
There is no "main menu" on this clock. Do you know this clock? There are 6 buttons on the back. The first being "Alarm On/Off." Then, "Alarm Set", -, + and icon that looks like a home and "Time Set." I would think that "Time Set" would have an option for 12/24 hour clock but it doesn't. Any other suggestions?
i'm still waiting...I ask "another expert" yesterday.
