Question about Caterpillar Watches
My watch stops when I take it off overnight and has to be reset every morning. it is battery powered
Posted by foxtrot223 on
Anonymous
    New Friend:
    Problem Solver:
  • 5 Answers
The problem is not with your watch it is with you you want to sleep and want the watch to work is it nice to trouble the watch let her sleep also and syou also sleep well when u get up time will stand still and you will be in 2012
Posted on Jan 19, 2010
Omega constellation self winding watch stops
Omega claim that your watch will run for 40 or more hours, so stopping overnight should not happen. I doubt if you need to be particularly active to wind up the watch, otherwise this would make the problem quite common. My one experience of owning an automatic did not raise this sort of problem.
Discuss your problem with your supplier and describe your use. As you correctly say, having to hand wind i defeats the point of buying an autoamtic. (It could be that you have been sold two duff watches, however unlikely this may seem, it could happen).
Jun 06, 2010 | Omega Constellation 95 1262.15 Watch for...
Screen goes blank and it says chg in small letters on the right lower side
Actually, "chg" means "change" in this case. Since this is a solar watch, it is not necessary to change the battery. I let my watch sit in the dark for a few months and I came back to the same screen when I dug it out of a drawer. Simply allow the solar cells to get some light to recharge. I left the watch under a lamp overnight because I needed a stopwatch in the morning, and it was charged by the time I woke up. Also, this watch has a power saver function you can turn on and off. If the watch is left in the dark for about an hour, the screen will turn off but the normal functions will continue in order to save power..
Apr 09, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
My watch, Seiko Kinetic Auto-Relay (5J22-OD60), no longer holds enough energy to keep working overnight, the second hand starts moving at two-second intervals and it stops before morning.
You have a bad capacitor. You can either try to repair this yourself with a special upgrade kit for about $20 (and maybe screw it up) or pay an expert who will do it right for $67.
http://www.qualitywatchrepair.com/seiko_kinetic.htm
For an extra $20 he'll do a pressure test on it to be sure it is water-proof but since this is a pro you really don't need to worry about it on a non dive watch.
Sep 29, 2009 | Watches
433LSLB stops working, sometimes overnight,
send it into skagen it has a lifetime warranty
http://www.skagen.com/service/orderWatchBandParts.fx
Aug 05, 2009 | Skagen 433LSLB Wrist Watch
My seiko stops overnight but works during the day
if the watch is solar power it may not be getting enough to last through the night. if it is battery powered it may just be stuck when in certin postion like upside down or somthing
Jun 03, 2009 | Seiko Kinetic watch
Can't shut off beep going off every hour
Hold down all four buttons to reset the watch. My time didn't reset but the beeping FINALLY stopped.
Mar 01, 2009 | Casio G-Shock G510D-1AV Wrist Watch
Timex rush new battery reset
good morning ! you need to use the pointed twisser to short the two reset pad ! thanks !god bless !...
Sep 02, 2008 | Timex Rush Sports Watch
I have an analog Fossill logo watch from my company. I notice recently that when I set the watch down flat, it stops. When I pick it up, it works. If I leave it down all night, it will be 8 hours late...
I would check the battery first, but I am going to put the odds on that it is a mechanical problem with the watch. It's not like in the old days when watches had a mainspring, where the power from the coiled metal was strong enough to push out any particals that got in the way of the gears teeth. Now they are all quartz, where any little piece of anything will stop the gears from running. If you haven't had this watch along time send it back via warrenty, if not it needs to be serviced.
Jun 27, 2008 | Fossil Watches
Watches Logo
843 people viewed this question
Top Caterpillar Watches Experts
Janelle Schoonover
Janelle Schoonover
Tom Chichester
Tom Lambert
Level 1 Expert
Are you a Caterpillar Watch Expert? Answer questions, earn points and help others
