Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Future CE-250 software compatible with Windows 7?
Laptop with Windows XP died. New laptop is running Windows 7. When installing CE-250 software get this error: Cannot run an x86 build on this utility on x64 platform. Does this mean the software is not compatible with Windows 7? If so, when will update be available?
Posted by mslbms on
Anonymous
    New Friend:
  • 6 Answers
I just bought a new Futura CE250 & had the same problem.
I fixed my "can not run an x86 build of this utility on x64 platform" by visiting the futura support website & downloading a service update. I have a computer with Windows 7 installed.
The website is www.futura-support.com
When you are there, click on the link on the left for "Service Updates."
The actual link to where I downloaded my udate is: http://www.futura-support.com/downloads/ce150.html
Happy Embroidering!!!
Posted on Oct 20, 2010
Anonymous
  • 64 Answers
RichterScale, it won't help.
mslbms, you need an update 3.0.0.9 that supports Windows 7
Posted on Jan 19, 2010
Richard Schabler
    Novelist:
  • 108 Answers
Vista does have a compatibility service for sotware that was made to run on pre x64 bit computer processors.
Microsoft Vista compatibility help center page.
Use this link for the details.
Instructions:
Run the Program Compatibility Wizard
  1. Open the Program Compatibility Wizard by clicking the Start button Future CE-250 software compatible with Windows 7? - 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
  2. Follow the instructions in the wizard.
If you cannot install a program, insert the installation disc for the program and, using the wizard, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The wizard is not designed to work on programs that have an .msi file name extension.
To change compatibility settings manually for a program, right-click the icon for the program, click Properties, and then click the Compatibility tab.
Hope this helps.
Why cant i install futura ce 150 softwRE with windows 10?
Singer Futura CE-150, I NEED HELP!!! - FreeEmbroideryStuff ...
freeembroiderystuff.embroiderydesigns.com/forums/threadView.aspx?id...
Jul 11, 2014 - 15 posts - ‎10 authors
I just got the Singer Futura CE-150 and every time I start a design it ... Posts: 2/10/2014 11:18:44 PM, RE: Singer Futura CE-150, I NEED ... Futura CE-100but didn't realize it didn't have its original install cd with ... I can't afford Singers price. ... -Software-Download-and-Installation_A287.aspx?id=287&siteid= ...
Singer futura ce-350 software download - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesJavaScript isn't enabled in your browser, so this file can't be opened. Enable and reload. ... Singer futura ce 150 embroidery machine 3900 designs dvd. Top 3 singer ... Singerfutura software for windows 10 memphis soft portal. Using my singer ... Singer futura software installation for windows 2000 xp youtube. Service ...
Singer Futura CE-250 Sewing and Embroidery Machine w
SINGER® FUTURA™ Software Installation for Windows ...? 7:20https://www.youtube.com/watch?v=RDkHyrh0ejkNov 30, 2009 - Uploaded by SingerSewingCompanySINGER® FUTURA™ Software Installation for Windows 2000 & XP ... yes i already have a singer ...Singer Futura will not work with Windows 7 - Microsoft Communityanswers.microsoft.com/.../singer-futura.../da1ea4db-8594-4a12-91d1-d8...I bought a Singer Futura sewing machine and a Win 7 laptop for Christmas. ... can find the right person at Singer to talk to they might let you have a pre-release version of thesoftware. ... What if you download the patch and it still doesn't work? ... if you are using ce-150 go to http://futura-support.com/downloads/ce150.html.
Dec 30, 2015 | Sewing Machines
Singer 250 can not run 86 on 64 platform
There is an update to give an x64 driver for the Singer CE-250 that will let you run on an x64. With the sewing machine not connected to the computer, install the software that came with the machine. Click OK at all of the "cannot run x86 build on a 64-bit OS" messages. When it is done, install the software from http://futura-support.com/products/ce-250/software . (The second one is for XP, Vista, and Win7 versions.) Accept the unverified driver (install anyway). After this completes, then connect the sewing machine to the USB port on the computer.
Similar patches exist for the CE-200.
I hope this helps. Please add a comment with the version number of your software. I know with Husqvarna Viking's 3D Embroidery, there are versions that can be upgraded to work with x64 and versions that are not patchable.
Mar 25, 2013 | Singer CE-200 Quantum Futura Computerized...
I have a ce-100 futura sewing machine that will not work with windows 7 what do i need to do to fix this problem
The Futura software and the machine drivers exist for Windows 98, NT, 2000, ME, or XP. If you have Win7 32-bit, you may be able to run in the compatibility mode. Load the CD into the optical drive, then right click on the .exe file on the CD. Then choose Properties. Select the Compatibility tab and check Run this program in the compatibility mode. Click Apply and OK. Then right click again and choose Run as Administrator. This isn't guaranteed to work since the changes in the OS are significant.
To check if you have Win7 32-bit or the 64-bit version, click Start > Control Panel > System and Security > System. The title will say Windows 7 (Version) for a 32-bit OS. It will read Windows 7 (Version) x64 for the 64-bit version of the OS.
If you have the 64-bit OS or the compatibility mode doesn't work, you need a computer running an older version of Windows. This can be a second computer, a dual-boot computer (where you select your OS at startup) or a virtual computer (that runs inside the real computer). If you have Win7 Pro or Ultimate or upgrade to one of those versions, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software from the above site in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS.
I hope this helps.
(The last person I dealt with with the issue of an embroidery machine not talking to Windows 7 kept their old Windows XP computer just to work with the sewing machine. Fortunately the old computer was still working enough to use for the purpose.)
Jun 28, 2011 | Singer CE-100 Futura Computerized Sewing...
Just bought this machine and installed the software. When I try to use I get a message: Can not run CF_Splash.dll
It sounds like you are trying to use the software on Windows 7 or Vista. There's a patch at www.Futura-support.com you'll need. On the lefthand side of the screen, click on downloads, then choose CE100/150/250/350, etc, etc. Follow the directions CAREFULLY. Be sure to install ALL Futura software you've already installed and reboot your PC BEFORE starting the new instructions.
If for some reason this still doesn't solve your problem, I've posted a solution that's a bit more involved on the CE100 Problems & Solutions home page for running your machine on Windows Vista/7. Basically, it allows you to run any XP program on Windows Vista or 7 using your old XP software. The Futura patch works for most people, though, so you will hopefully not have to go that route.
Happy embroidery!
Feb 15, 2011 | Singer CE-100 Futura Computerized Sewing...
I have a Futura CE-100 and got a new laptop with Windows 7 and can not get the software to install. Gets to 100% and won't complete. How can I fix this?
First, there's a Windows 7 update available at www.Futura-support.com. Click on the lefthand side, then on CE100/150/250/350, etc, etc. Follow the directions CAREFULLY. First, be sure the uninstall ALL Futura software you've attempted to install and reboot your PC.
If for some reason this doesn't solve you're problem, I've posted a set of instructions at http://www.fixya.com/support/r8955271-use_machine_windows_7_or_vista that will allow you to run the software under XP on your Windows 7 machine. This is a bit more complicated a solution, but if you follow the instructions carefully, you should be fine. Try the Futura update first, though.
I hope this solves you're problem. Happy embroidery!
Nov 23, 2010 | Singer CE-100 Futura Computerized Sewing...
Singer futura ce200 software problem
You may ask your Singer supplier about Futura 2.5, this version of the software supports old machine models ce100/200, contains more features like the software for newer machine models and works under new OS including Windows 7.
Mar 22, 2010 | Singer CE-200 Quantum Futura Computerized...
For Singer Futura CE 250. New laptop with windows 7? Loaded software & tried 64 bit Vista update patch - it doesn't work. Is the newer patch available for download? Can't use Live Update because...
Update with WIndow 7 support is already available at:
If you applied wrong patches you will have to uninstall Futura, reboot, install from the beginning the basic version and then apply an update 3.0.0.9
Jan 03, 2010 | Singer CE350
Singer ce150 Windows 7, unable to install drivers. Is there a work around for this? I have tried compatibility for Win XP service pack 3, and other Win versions, that my other laptop is running but still...
Due to obligatory special sertificate for driver installation under WIndows 7 all Futura updates are delayed. As soon as Singer will break through beaurocratic procedures all updates will be released, firstly for newer models, then for older.
Dec 06, 2009 | Singer CE-200 Quantum Futura Computerized...
Futura CE-200 Software fails to initialize on XP sp2
Maybe you should try to contact singer south africa and ask them whats wrong, my laptop did the excact same thing switch over to home pc and no problem ever again.
Mar 02, 2009 | Singer CE-200 Quantum Futura Computerized...
Futura CE 200 Software Installation Media
Yes, from here: Driver Update Software for XP Vista 7 8 Install this software and make the update. Wish you best of luck.
Peter
Nov 02, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
1,770 people viewed this question
Top Singer Sewing Machines Experts
Irene Tulloch
Chris Wetmore
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
