diy.stackexchange.com/
questions/.../how-do-i-remove-a-stuck-
faucet-tap...
Apr 18, 2011 - Anybody can ask a question; Anybody can answer; The best ... There are total six faucets in a bathroom, two made into a bathroom basin ... The other possibility is that there's a small plastic "decorative" cap covering the screw.
toolmonger.com/2009/12/01/how-to-replace-a-
shower-
faucet-cartridge/
Dec 1, 2009 - In many modern shower faucets like Delta and Moen (which is what I have) .... About a year ago, one of the bathtub faucets in my other bathroom jammedopen. .... the exact faucet I have in my shower, so you answered my first question, ...I can tighten and loosen the screw but the handle just won't come off!
www.diychatroom.com/.../problem-removing-handle-off-delta-monitor-...
May 20, 2009 - 15 posts - ā12 authors
... from a Delta Monitor 1400 series tub/shower single handle faucet. ... sorry for the REALLY sxxxxx question. which way to turn (loosen) the set screw. ... only suggestions i have on the issue. when a setscrew will not back off i ...
www.diyforums.net/removal-of-stuck-curved-
faucet-handle-with-hex-
sc...
http://dunbarplumbingforums.com/DUNBAR/i...
On those Delta tub/shower Monitor faucets:
If you have a cartridge that you removed that has a light green assembly, almost a translucent/light green...those cartridges were defective due to the certain chemicals in the water in this area, and the new style cartridges (blue and white) address this issue inside the the cartridge.
The reason why it was bad/defective was the water would damage the internal housing and cause the balancing spools to stop moving inside the cartridge.
If your cartridge isn't new, or isn't blue on the backside, if you take your cartridge apart you'll see a guide plate which is stainless steel. This is the mating surface of the assembly where the rubber seats mate with the guide plate to seal and distribute the water.
What happens in the older ones is the plastic tabs that hold that guide plate in position start to lose their ability to hold the plate in position, and the plate from turning the valve on and off thousands of times causes those tabs to widen, allowing the guide plate to have motion. <<< There is where the leak can recreate even with new seat cups and springs.
There is no fix for that issue other than replacement of the cartridge. The cartridge is around $47 from Lowes or Home Depot or any supply house.
Top left hole would be the hot water side, and that water coming out was thermal expansion created from the heating of water...which is normal.
You can heat a tank of water in a water heater, cut the water lines off right at the top and water will slowly leave that tank for hours, without a source of water. Same principle of heating water on a stove...turn the heat up the water will expand and try to push the lid off the pot.
