Question about HP Photosmart C4180 All-In-One InkJet Printer
Screen showing the message "remove and check right cartridge". Have done this several times and still can't print
Posted by anita_davis on
Anonymous
    New Friend:
I've had the same error:
Hold down the following keys:
Photosmart Express, Photo Fix, Reprints, Print Photos and then Help.
You'll get the message: "Enter Special Key Combo"
Press OK.
Scroll over to Reports then self test: and press ok, it should print. a selftest report.
If you get an error Pen in Chute 1, or 2, has tsr failure: Call/Chat with an HP technician.
Posted on Jun 18, 2010
John Brown
    Novelist:
  • HP Expert
  • 95 Answers
The issue of Hp Printer Error Code 41.3 generally causes when there is more than one sheet is sticking together in printer or the tray is not properly adjusted.
You have to follow few steps to fix the issue. In order to fix these kinds of issues, I am going to share a link of a blog from where I got the solution to these kinds of issues.
Read the blog:-
www.hptechnicalsupportphonenumber.com/blog/fix-hp-printer-error-code-41-3/
Posted on Apr 01, 2020
Rod Eslinger
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • HP Expert
  • 307 Answers
For severe cartridge error messages on the Photosmart C4100 series printer models (i.e. Replace Cartridge, Cartridge in wrong slot, Not Intended for this Printer, etc.) which prevent printing, conduct a 'tap 41' diagnostic test. The 'forced service test print' may be used to evaluate the cartridge's electrical health; often the ink cartridge is internally damaged when these types of errors occur; it is suggested you ensure cartridge's rear electrical contacts and printer flex driver cable contacts are clean before assuming the cartridge has failed. For more detailed information on HP 92 thru 99 ink cartridge error messages please visit:
http://inkjet411.retailinkjet.com/?page_id=1216
Photosmart C4100 Printer Series Tap 41 Cartridge Health Diagnostics Procedure (Reference video - HP 74/75 cartridges are electrically identical to HP92-99 cartridges): http://inkjet411.retailinkjet.com/?page_id=1741):
1. Press and HOLD the 'LEFT ARROW' button.
2. Press the 'Setup' button (wrench icon). Release both buttons.
.......or alternatively, press the following five (5) buttons simultaneously: 'Photosmart Express' + 'Photo Fix' + 'Reprints' + 'Photos' + 'Help'
3. At "Enter Special Key Combo" menu, select 'OK'. 'Support' menu should be displayed.
4. Click the Right Arrow until 'Reports Menu' is displayed.
5. Select Ok. Click Right Arrow until the 'print-mech button tap' menu is displayed.
6. Select Ok. ('code = 0' will be displayed); click and hold Right Arrow until 'code = 41' is displayed.
7. Select Ok. The test page prints. Refer to video on how to read the test print.
NOTE:A good HP 93/95/97 color cartridge should display 600 good nozzles, while a good HP 92/94/96/98 black ink cartridge should show 672 good nozzles. Refer to video link above.
Visit Inkjet411 for more information: http://inkjet411.retailinkjet.com/
Posted on May 30, 2013
2 Related Answers
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: remove and check cartridge
Replace all ink cartridges at the same time.
Posted on Jan 23, 2009
don_farr
Don Farrell
  • 1018 Answers
SOURCE: message says: remove and check right cartridge.
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Posted on Feb 19, 2010
My hp officejet ignore printing after replacing of cayne colour cartridge.
I hope Magenta cartridge is not refilled one right? :#Remove all cartridges and print heads, disconnect power & USB cable, switch off wait for couple of minutes.. give power switch on the machine wait do as per the message appears on display.. once installed cartridges and printer heads wait for the ready mode:.. once ready mode appears attach USB cable then print and see..# check with old and new cartridge see the difference of message.. if both messages are same it might be problem with ISS(Ink supply station) faulty, try it get back to us..for further remedies.
Feb 03, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
Printer error 3515
Kodak ESP-5 error message 3515....tried Kodak way but didn't work....could hear the print head attempt to move but couldn't...unplugged unit from power....opened to expose the print cartridges...removed small screws on sides and back of printer...gently pry open top....turn gears on right side with finger toward front several turns.....check and see if print head will now move to center....(I removed cartridges and print head so I could see the blotter under print head move to back position. Re-installed print head and cartridges.) plugged power cord back in and turned on...unit cycled and then screen showed normal....replaced screws in top panel.....printed test page...back in operation......Don't be heavy handed....plastic will break very easy I think when opening panel if not careful...
Dec 28, 2010 | Kodak ESP 5 Printer
My hp2400 series printer is stuck on the message "Remove and check the right cartridge". I have done this several times and it still doesn't work/ Please help.
If this is a new cartridge make sure the shipping tape has been removed from the print head before inserting into the printer.
Oct 31, 2010 | Computers & Internet
Message says: remove and check right cartridge.
Don
Feb 19, 2010 | HP OfficeJet 4215 All-In-One InkJet...
New tri-color cartridge has a problem. I can't see what.
I have an HP Photsmart C4100 printer. I purchased remanufactured ink cartridges (both black and tri-colored) from Vivasmart. The black one works fine, but when I installed the tri-color, I got an error message that says "Print cartridge problem" The following print cartridge has a problem:
Tri-color.
And I can't print. The screen on my printer says "Remove and check color cartridge." I have done this several times and it still won't print. I have turned off the power, removed the cartridges, and unplugged the unit, but it still didn't help. Any suggestions?
Jul 21, 2009 | HP PSC 1510 All-In-One InkJet Printer
Remove and check cartridge
Jan 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    "remove and check cartridge" error message
    http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=buu02180&cc=in&lc=en&dlc=en
    I resolved the "remove and check cartridge" issue after reading the instructions at the above address. Most importantly, I replaced both cartridges and the problem was resolved.
    The color cartridge appeared to be the issue. It had been in for months and used infrequently.
    May 30, 2008 | HP OfficeJet 6110 All-In-One InkJet...
    HP Photosmart C4180 All-In-One InkJet Printer Logo
    1,036 people viewed this question
    efs_perpends
    efs_perpends
    Muntejaya Ginting
    Muntejaya Ginting
