I agree with govinda123 that the first step would be upgrade the firmware, assuming that you're having this same issue on more than one computer (have you tried another computer??). Once you have the firmware file downloaded (which is free from linksys.com) you have to log into the web interface of the router, go to the firmware upgrade section and browse to that file.
If have the same issue after updating the firmware, I would change the DNS servers to see if that makes a difference. Also in the web interface of the router, you can hard code the Primary and Secondary DNS address with the numbers below from OpenDns.com.
208.67.220.220
208.67.222.222
If that does not help, I would consider replacing the modem.
You will need to upgrade the firmware. you have already downloaded the firmware. that file is .bin file . you will not be able to open that file. To upgrade the firmware, you will need to open the set up page of the router.
click here to know more about routers and network
once logged in in the right hand corner on the facebook homepage you will see ACCOUNT from the drop down list will be Edit friends Account settings Privacy settings Help center and Log out
internet search facebook login
you could use the help center type in you problem you might have to wait a for 2/3 days for a reply due to overloading on this site
hope this helps
when you get requests to access any or personal information of your profile you should see who is asking and who will have access to it once you click yes all of your information can be accessed by?????
click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in facebook.com) or your preferred homepage browser
http://www.filebuzz.com/fileinfo/87599/Facebook_Login.html
Facebook Login software is freeware specially designed for Facebook browsing. This simple application has many features for you. Application is more speeder and secures Facebook browsing than your normal...
Hope one these will help you
once logged in in the right hand corner on the facebook homepage you will see ACCOUNT from the drop down list will be Edit friends Account settings Privacy settings Help center and Log out you could use the help center type in you problem you might have to wait a for 2/3 days for a reply due to overloading on this site
hope this helps
hope this helps
Hope one or some of these will help you
once logged in in the left hand corner on the facebook homepage you will click on edit my profile then on profile picture which you can remove across to the right you will see a browse tab where you can browse to your new photo to upload
hope this helps
hope this helps
click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in facebook.com) or your preferred browser
hope this helps
internet search facebook help
type in your problem it might take a few days to get a reply due to demand on the site and weekends
internet search type in facebook login you should see a tab forgot password it might take a few hrs or days weekends might not be included for facebook to recognize the changed password because there so many people having the same issue which will be overloading the site
once logged in in the right hand corner on the facebook homepage you will see ACCOUNT from the drop down list will be Edit friends Account settings Privacy settings Help center and Log out you could use the help center type in you problem you might have to wait a for 2/3 days for a reply due to overloading on this site also
hope some of these will help you
hope this helps
hope this helps
hope this helps
hope this helps
hope this helps
hope this helps
hope this helps
hope this helps
hope this helps
hope this helps
