Question about Brother MFC-9440CN Laser Printer
Black dots on printed page from Brother 9440 color laser printer
Hello. I think I need to clean the printer...how do I go about doing that with this Brother 9440 color laser? I have black dots all over a printed page more towards the middle. Thanks.
Dave
Posted by davesandberg on
Anonymous
  • 240 Answers
The problem lies with the black toner cartridge. This is a common problem in these machines due to poor design by Brother. Best solution is to replace the offending color toner cartridge.
Posted on Jan 19, 2010
How does one 'colour test' please.
Clean the Printhead & Print a test page by doing the ff:
1. Press the Ink button press the Up or down arrow key to select Test Print, then select Print Quality press OK and press Black or Color START. Check all the colors including the black & check if there are any missing dots and if there are any colors not printing correctly.
2. Press the Ink button on the control panel and select CLEANING press OK.
3. Press the up or down arrow key to select Color press ok and press Black Start.
*After the cleaning process the printer will ask you if the quality is OK, press up or down to select yes or no, and it will ask you whether black or color is ok, once you have selected you're answer press Black or Color START to print another test page. Compare the 1st and 2nd test page if it's improving, you may need to do this 3-5 times or until you get a better quality
Hope this helps Please rate if it worked Thanks!
Apr 03, 2011 | Brother MFC 490cw Color Inkjet...
My Brother inkjet printer (DCP-585CW) is not printing yellow colour.
If the yellow ink is not printing here's what you can do:
1. Press the Ink Management button press the Up or down arrow key to select Test Print, then select Print Quality press OK and press Black or Color START. Check all the colors including the black & check if there are any missing dots and if there are any colors not printing correctly.
2. Press the Ink Management button on the control panel and select cleaning press ok
Hope this helps.
Rate if it worked Thanks!
Apr 03, 2011 | Brother DCP585cw AllInOne InkJet Printer
When I test print, I do not get a full pattern of black dashes. I changed ink cartridges and have the same result. The color test prints are fine
If you are missing dots it is due to the print head not the cartridge.
Try doing a self cleaning a few times (max of 5) by pressing "ink" and select "cleaning"
If after 5 cleanings there's still a problem, you may need to have the printer serviced or replaced.
Since you're still getting most of your dots though, I think the cleanings should clear it out.
Thanks,
Pat
Mar 31, 2010 | Brother Multi-Function Center MFC-240C...
How do I set Brother 9440 MFC to print using black cartridge only?
You can set the MFC-9440CN to print with the black toner cartridge only through the printer drivers.
If you are using Mac, this needs to be changed before you print or set a preset.
If you are using windows, follow the below steps.
1. Go to Start menu \ Control Panel \ Printers (devices and printers for windows 7)
2. Right click on the MFC-9440CN and select "printing preferences"
3. Under the "basic" tab, you will see "color mode"; simply select "mono"
Thank you,
Mar 28, 2010 | Brother MFC-9440CN Laser Printer
MFC-9440 CN Laser Printer is producing vertical color line streak
Colored vertical streaks - looks like a transfer belt problem, and it's not user fixable. You may need a new belt unit - you can find it for around US$ 80-120, but you may want to have a technician inspect the unit first, since it could arguably be the drum instead, and you don't want to fork around US$ 100 and replace the wrong part.
You can try showing a printer sample at a print shop; by looking at the streaks it is possible to diagnose drum, fuser or belt problems.
Here you find a much more detailed page, for another printer model, but the issues are mainly the same for most color printers:
http://www.laserquipt.com/support/idx/26/452/article/Toner-Smearing-Issues.html
Mar 25, 2010 | Brother MFC-9440CN Laser Printer
When I print I have black dots on it and a red
The drum probably needs to be cleaned. Refer to the Routine Maintenance section in Appendix C of your Users Guide.
Oct 08, 2009 | Brother MFC-9840CDW Laser Printer
Hp2600n printing black dots centre page
Could be a dirty fuser, try a laser printer cleaning sheet.
This is more of a problem if you use (some types of) remanufactured toner cartridges.
Feb 04, 2009 | HP Color LaserJet 2600n Printer
Magenta Dots vertically on Left margin of page
That is referred to as a repeating defect...most likely caused by a defect on the magenta drum unit. Here is a link for information on how to repair this problem:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000016/faq000216_016.html?reg=us&c=us&lang=en&prod=mfc9440cn_all&Cat=3
Jan 17, 2009 | Brother MFC-9440CN Laser Printer
BROTHER MFC-9440 CN all-in-one
hi, i fixed this problem but do have another however your solution might be to clean each cartridge using the user accesible sliders on each cartridge. they can be found by lifting each cartridge in succession and flipping the white cover up. on the left is a green knurled thumb thing. slide it back and forth 2-5 times and repeat for each cart.
good luck.
h
Oct 07, 2008 | Brother MFC-9440CN Laser Printer
Coloured dots
Maintenance - BTR Adj - Plain 1 - 5 to 8
Feb 15, 2008 | Dell 3000cn Laser Printer
Brother MFC-9440CN Laser Printer Logo
1,648 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
