Question about Westinghouse Dishwashers
Can you tell me what temperature the dishwashers reach during each part of cycle--Dishwasher model is WDF902SA Food authority have asked this of me
GPEC
    New Friend:
  • 12 Answers
The wash temperature for a high temperature commercial dishwasher should be around 140F AND 160F. The final rinse temperature should be 180F to meet health code regulations. The final rinse temperature is reached during the end of the cycle for a few seconds. If the machine is a low temperature dishwasher the wash temperature and rinse temp will be around 140 F to 160 F. The sanitizing of your warewash will be done by the use of chlorine or iodine in the low temp application.
Regards
Posted on Jan 18, 2010
Testimonial: "Thank you for response"
Dishes remain dirty, Food particles all over interior of dishwasher. hotpoint dishwasher model HDA2030Z02WW
In the back of the dishwasher at the base there is an indentation. This is where the food particals go when they are washed from the dishes. In this indentation there is a filter and a small wire appendage that is connected to the impeller of the motor. What happens is the dishwasher takes the food off the dishes and it is washed into this indentation area where the wire appendage turns breaking up the food particals to be flushed out during the drain cycle. What it souds like is this filter is clogged to the point no further waste can be flushed out. If you take the bottom tray out and reach into this indentation you will feel the filter. (note) there is a cover over this area that will need to be removed to access this filter. Once the cover is off you can reach into the area and you will feel the filter which should pull up and out. Be very carful when reaching into this area due to broken glass particles that may have accumulated. Once the filter is out clean the area well and replace the filter and you should be good to go
Hope this helped
Dave
Mar 31, 2010 | Dishwashers
Hi I have a Blanco dishwasher BFDw8 which is having poor wash results in the top tray I have tried all the trouble shooting things in manual. Investigated further by opening door during wash cycle several...
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
Scrape away large pieces of food, bones, pits, toothpicks, etc. Burned on food should be loosened before loading. Empty liquids from glasses and cups. Foods such as mustard, mayonnaise, vinegar, lemon juice and tomato products may cause discoloration of stainless steel and plastics if allowed to sit for a long period of time. Unless the dishwasher is to be operated at once, it is best to rinse off these food soils. Load racks so that large items do not prevent the detergent dispenser from opening. If the dishwasher drains into a food disposer, be sure disposer is completely empty before starting the dishwasher.
just click on the above questions for more help the answer will come to the screen
  1. A common leaking trouble maker
  2. Another common leaking trouble maker - especially for leaking out of the door area
  3. Can I use a rubber or plastic hose for the hot water on my built in dishwasher ??
  4. Some common pump assembly pictures...
  5. Dishwasher Basics
  7. Dishwasher soap notice
  8. Draining and washing help
  9. Help for storing an appliance
  10. How to remove the access panels
  11. I just installed my food waste disposal, now my dishwasher will not drain, what could be wrong??
  12. I moved and lost the tap adaptor for my portable d/w, help!!
  13. Important disclaimer
  14. I would like to try to install my own dishwasher
  15. Loading your dishwasher help
  16. Motor and pump assembly screw and impellor help
  17. My dishes are not as clean as they used to be, what might be wrong?
  18. My dishwasher racks have rusted.
  19. My dishwasher will not fill with water
  20. My dishwasher will not start
  21. My soap dispenser will not open
  22. Sand like deposits inside the glasses and d/w
  23. Some common soap door dispensers breakdowns
  25. Stainless Steel Cleaning
  26. Strange grinding noises and not washing properly
  27. The dishwasher doors falls down
  28. White filming on the glasses
Oct 05, 2008 | Dishwashers
My Dishwasher is DS603 and it stop on minutes 26 during a cycle and never continue.
Hi- sounds like your heater plate is bad. The cycle wont continue unless the water reaches a specific temperature for that point in the cycle.
Mar 08, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Du1100xtpq7 has had the touch pad replaced along with the circuit board that goes behind it and yet it just keeps repeating the wash cycle and goes for hours
i would guess that you are having a problem with the optical sensor inside the pump housing. it is suppose to sense when the water is clean or dirty and allow the unit to continue washing or advance to the next cycle.
i have seen these test good but be just out of calibration enough to cause long run times.
you can try to change it yourself or have the service company try that instead of a new board and panel.
Jan 07, 2010 | Whirlpool 24 in. DU1100XTPS Built-in...
Dishwasher stalls
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
May 31, 2009 | Bosch SHU4006 Dishwasher
Running time of dishwasher
he cycles times are too long If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Cycle not completing See "The cycle doesn't complete" section.
The cycle doesn't complete If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Mar 14, 2009 | Bosch Dishwashers
Cycle runs for 2-3 or more hours
If your dishwasher's cycle times are too long, check these: Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
Cycle not completing f the cycle doesn't complete, check these:
Oct 23, 2008 | GE Nautilus 24" Built-in Dishwasher
Frididaire dishwasher HO on display screen
If it is coming on during the cycle it means the dishwasher is heating the water. If it is after the cycle or the cyle is stopped it means it did not reach the proper heat temperature. As long as it is running through the whole cycle it is ok.
Jun 13, 2008 | Frigidaire Dishwashers
Dishwashers Logo
255 people viewed this question
Top Westinghouse Dishwashers Experts
Michael Thomas
Michael Thomas
Lawrence Oravetz
Terry
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
