Question about Jabra BT350 Bluetooth Headset Headset
I have a Jabra 2050 headset and my blackberry recently got reset by IT so I want to "repair" the headset but lost the code....
Posted by lancesfox on
Anonymous
    Problem Solver:
  • 8 Answers
TRY 0000 (4 ZERO)
Posted on Jan 26, 2010
Need a password to connect my jabra 2050 to my blackberry lost connection
Try to the most common codes. 0000 ( four zeros ) and 1234 are the most likely to work.
Oct 15, 2010 | Jabra BT2050 Bluetooth Headset
Im trying to connect my Jabra BT350 to my blackberry 8520 but my blackberry bluetooth wont even find the device even the Jabra headset is turned on.....i also lost my Jabra BT350 user manual cd and i dont...
The headset has to be in learning mode first for any phone to find it, press and hold the power on button for 8 seconds until the power light comes on and stays on then search for it with your phone, pairing code can be 0000
Aug 29, 2010 | Jabra BT350 Bluetooth Headset Headset
I bought a jabra bt 2050...i cant get the led light to stay on..it only wants to flash...and it wont pair with my blackberry storm
Try to press and hold the center on/off button for 10 seconds, this will put the Jabra BT2050 into paring mode.
Assumptions made:
1) The BlackBerry is Bluetooth enabled.
2) The Jabra BT2050 is fully charged.
Hope this help.
Joseph
Jan 05, 2010 | Jabra BT2050 Bluetooth Headset
Jabra 2050 wont pair with blackberry storm
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Sep 05, 2009 | Jabra Bluetooth Headset with Adjustable...
Lost instructions to my Jabra VBT 2050, how do I turn it on??
try holding call button down for 10 seconds on that one, it shold start blinking, than remove your thumb as soon as it starts blinking, to turn it off reverse the process, remember passkey is 0000 or 1234. good luck
Jan 11, 2009 | Jabra BT350 Bluetooth Headset Headset
Lost my passkey for jabra 2050
the standard pass key for the jabra vbt 2050 is 0000.
it worked for mine
Jan 05, 2009 | Jabra Bluetooth Headset with Adjustable...
Jabra 250 Codes
To make this complete: You need to turn off the headset (hold call button several seconds until it makes descending tone). Then hold button to turn on and keep holding 8 seconds more until blue light is on solid. Then initiate pairing at phone, and enter 0000 as the code.
Mar 24, 2008 | Jabra BT250 Consumer Headset
Jabra BT350 Bluetooth Headset Headset Logo
93 people viewed this question
Top Jabra Radio Communications Experts
Marvin
Marvin
 Grubhead
Grubhead
Harish  Ramaiah
Harish Ramaiah
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
