Question about Whirlpool Freezers
My ice maker wont deliver ice. can you help - Whirlpool Freezers
Posted by beechbeds on
Dan Webster
  • Whirlpool Master
  • 8,220 Answers
Ice maker/ ice dispenser manual HERE
If the ice maker mold is empty try adding some water. Wait. If a batch of ice pops out then water valve replacement is in order. If it fails to pop out a bit of ice then the ice maker is bad. I have more information on a page I created HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 18, 2010
F-330bah-c stopped making ice & unit is 1 month old
it should be under warranty . is the water shut off to fridge . ice maker could be bad . make sure water to the ice maker is on just check your water line . a very easy common mistake and very easy fix if the water is not turned on to the ice maker it wont make ice . hope this helps let me know how it gos
Nov 02, 2013 | Hoshizaki Freezers
Ge profile refrig - watrer dispenser does not deliver water. Ice maker works fine. What is wrong?
Water solenoid at the rear of the fridge has failed, there is two or three solenoids there, locate the one that does water feed to the door (not ice maker) and do a load test or just replace. Also make sure you dont have a filter safety cut-off, check filter cond and it is located perfectly in housing, check lines inside and outside fridge unit for obstructions. Good luck.
Feb 27, 2011 | Continental Freezer Wide...
My ice maker does not work
Good day,
The freezer must be below 12 degrees before the ice maker will activate. If it's o.k. then follow the steps outlined below. It will solve your problem.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Nov 28, 2010 | Kenmore Freezer 20.6 cu. ft. Upright...
My ice maker isnt working in my fridge model 106 59292993 the bar is in the down position like it is supossed to be and it sounds like its trying to make the ice but just isnt, do you know why?
Good day,
First off the freezer must must be at 10 degrees or lower. The ice-maker will lock out automatically at any temperature above 12 degrees.
Follow the steps. It will get you there.
Nov 27, 2010 | Kenmore Freezers
When the room is full stop making ice , the problem is leaking water with rush from the ice maker
Good day,
don't understand your question at all. When room is full. Full of what ??
But for know, I'll include a step by step procedure for repairing ice makers. Any further questions, please just ask..
Mar 31, 2010 | Freezers
We have a nice ice and it has worked fab for three years but has just stoped making ice yet is still operating normally
Good day,
Without the make and model, I could be missing something, but ice makers are more alike than different. The best way, is to follow a step by step procedure. It should solve your problem.
Mar 28, 2010 | Freezers
The ice-maker in my Daewoo Fridge Freezer (FRS-U20DAI) is not working. The ice tray does not empty.
is there ice in ice maker but it wont empty?
the ice maker has built in heater underneath. thats how the ice detaches itself from the ice maker and the fingers rotate them out.. if you have ice in the ice maker then replace ice maker
hope this was helpful
Mar 27, 2010 | Freezers
Fridge Freezer model KA58NP90 Ice maker problem
What is most likely your problem is the crushed ice solenoid. This solenoid, which is located next to the auger motor behind the ice bucket, is failing to actuate when you request cubed ice. Its "home" setting is crushed, and actuates to allow cubes past the crushing mechanism in the bucket. To be certain its the problem, remove the ice bucket, and tape the door light switch in the closed position. actuate the ice dispenser lever, for both cubed and crushed ice. you will see a square hole next to the rotating fork, when you select cubes, it should open. If it does open, there is something wrong with your ice bucket, perhaps the arm is broken, or the door inside bucket is off its snap in type hinge or broken altogether. If it doesnt open, replace the solenoid
Expert Refrigerator Repair Service in Chicago and Suburbs
Mar 20, 2010 | Freezers
Water line to freezer pops out when water is delivered.
try putting a small one way valve at the end of the line so it wont back up. or put more insulation around the hoses
Jun 06, 2009 | Frigidaire Freezers
ICE MAKER MOTOR RUNS CONSTANTLY AND WONT' TURN OFF ICE IS FULL
It's not too difficult to remove the ice maker. A few screws and the unit will unplug from the fridge. Then you can see why the bar is not turning it off. If it's really broken, check pcappliance.com for parts or a replacement unit. Meanwhile the fridge can keep on working, and you can use trays to make ice.
May 03, 2009 | Jenn-Air Freezers
Freezers Logo
147 people viewed this question
Top Whirlpool Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Dennis Boxerman
Lawrence Oravetz
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
