Question about Toshiba e-Studio 205 Copier
Call for service no code scanner moves then stops immediately
Posted by bwking64 on
digivisionm
    New Friend:
  • 40 Answers
Check scanner ribbon cable
Posted on Jul 17, 2010
Anonymous
    Champion:
  • 224 Answers
Sounds like a service technician is required
Posted on Mar 31, 2010
A1E error code. We have a fi - 5900c scanner and its throwing a A1E error code. it will not initialize correctly. I sounds like the motor that moves the exit try will not stop moving up and down. we took...
I think you mean E1A which is the code of Death for a Fujitsu 5900C
It normally means get your big fat wallet out and buy a big fat large PCB for £1000's of pounds . But there is a Cheaper fix by miles .
Jun 11, 2012 | Fujitsu fi-5900C Pass-Through Scanner
I have been driving Pontiac Montana 2003 with an excellent company maintenance service, just got the 100,000 miles point and last Sunday it looked that the car lost electrical power turning off at the...
Hello
Your OBD II scanner doesn't read the BCM (Body Control Module) and likely that is what has the fault codes in it for your present problems. At this point I suggest you get a GM dealer to scan the BCM with the special scanner (called a TECH II) required to do the check and see what shows up.
Aug 24, 2011 | 1999 Pontiac Montana
I have an hp m2727 with a scanner issue,, after reboot,scanner moves back & forth on the right side, lamp blinks erratically, comes to Ready,NO error codes,,, but the scanner will not move when you try...
This type of failure usually will cause a Scanner 5 or 8 error on the control panel but not always. HP has a Service Advisory that will cover any unit manufactured before January 1, 2010. Contact HP immediately as this advisory expires soon. Any HP service partner can fix this for you but I have found that many do not even know that this advisory exists. Be insistent, this is a more common problem than HP will admit
Feb 18, 2011 | HP Laserjet M2727nf Multifunction Printer
How do you program a bearcat bc55xlrt scanner with a code?
There are no codes, only frequencies. For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
To program your BC55XLT:
Turn on radio.
It will be in scan mode. Press Manual (orange button) to stop scanning.
Press Manual button to step through channels to get to the one you want.
(Or press channel number and then manual button)
If "LockOut" is displayed it means this channel isn't being "Scanned."
You will want to lock out constant "broadcast" services such as NOAA or airport weather. Pressing Lockout will toggle the feature on and off.
Select a channel to program. Use the keypad to enter frequency. Use "E" for Enter
key. If the radio displays an E this means Error. Usually, the
frequency you typed in is outside of the capabilities of the scanner.
Once you hit the E you will immediately start hearing anything that's
out there on the frequency you entered.
Push the "Review" button and the scanner will display the frequency
that is programmed for the channel. A "-" will be displayed for the
decimal point.
Jan 12, 2010 | Radio Communications
My photocopier AR-F152 IS NOT WORKING,the L2 flash on the lcd
an l2 code is your scanner is not moving. sometimes the little lock under the scanner section get pushed or turn. this is stop the scanner from moving in transport. it is right above where the paper comes out. you will have to look for it. it protudes uner the glass to stop the scenner.
Dec 28, 2009 | Sharp AR-F152 Fax
I have the LS4071 scanner and I'm using it with Quickbooks for my retail store. When I scan an item the code scans perfectly in the "Item" window but it does not advance to the "Description"...
Yes...you need to set-up the scanner with a new "Suffix" -- contact the Symbol Help Desk at 1-800-653-5350 and they will help you.
Cheers.
Billy Barcode
Jul 29, 2009 | Symbol LS 4071 Handheld
Sharp AR-337 COPIER SCANNER LOCKS UP
Do you know how to get into the simulation mode
Like Clear ,exposure mode, clear , interrupt, are you familar with the service manual procedures ?with Sharp, are you an independant dealer. ? into simulation mode and run the Scanner mode, make sure it run back and forth ok, lubricate the track, if it gets stuck it will produce and error or stop running.
Before i can help you I need to know your expretise.
Mar 08, 2009 | Office Equipment & Supplies
Constant static
Sounds like a tech problem internally, may need cleaning on the pot. A service center can fix it. Or could be an Ant problem? Check your Ant connection make sure they are good and not dirty. Mositure in our homes builds up inside and on all connection. 1200 grit Sand papers works well on ant connection. Or did you move the scanner? that will cause problems as well.
Feb 15, 2009 | Radio Shack Pro-2052 Scanner
Printer problem
There is some problem with your integraed scanner in office all in one. But your printer should work fine.
But you may not be able to sned or receive faxes as it needs the scanner to be functional.
If you can lubricate the rails of the scanner assembly, it become moving again.
Otherwise get it serviced.
Jul 23, 2006 | HP PSC 2355 All-In-One InkJet Printer
Toshiba e-Studio 205 Copier Logo
57 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Timothy Van Der...
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
