Question about OKI C6100n Laser Printer
I went to the printers and faxes menu. i clicked on cancel all jobs for the printer. no luck. printer is still printing. i used the canceling mode at the printer. still no luck.
Posted by manhattansha on
mkolufadi
  • 154 Answers
Next Time remove the Printer power cable, then unplug it from your PC, restart the printer. then Check all the process again try printing a page then on the bottom right of your task bar (start up) you will see a printer icon, double click to open and then delete the printing
NOTE: it is better to cancel printing from the Printer itself and Delete printing from the PC, because before the PC sends a cancel command to the Printer the document would have finished Spooling at this point the printer does not need the PC to print
Posted on Apr 18, 2010
HO C4200 DOCUMENT STUCK IN QUE CAN'T DELETE
First You Need to Open the Print Queue, follow the below steps on how to open a Print queue
  • Windows 98 - click Start, Settings, Printers
  • Windows XP - click Start, Printers and Faxes
    or click Start, Control Panel, Printers and Faxes
  • Windows Vista - Start, Control Panel, Hardware and Sound, Printers
Double click on the appropriate printer to open up the Print queue,Check whether you have any pending or the queued jobs, try to cancel the jobs by following the below steps.
To cancel one or more print jobs, follow these steps.
1. Click Start, and then click Run.
2. In the Open box, type control printers, and then click OK.
3. Right-click the icon for your printer, and then click Open.
• To cancel individual print jobs, right-click the print job that you want to cancel, and then click Cancel.
• To cancel all print jobs, click Cancel All Documents on the Printer menu.
If you are using an HP printer and a windows vista operating system then you are lucky to automaticlly fix the issue with the HP Print Diagnostic UtilityClick Here For How to cancel printing or to delete a print job that is stuck in the print queue in Windows XP.
Alternatively You can check the below steps.
Delete Pending Jobs
How To Restart Spooler restart In Windows Vista
Click the Start button.
Click Control Panel.
Click System and Maintenance.
NOTE: This step is not required when using Classic view in Windows Vista.
Click Administrative Tools.
Double-click Services.
On the User Account Control window, click Continue.
Click Print Spooler.
Click Stop to stop the Print Spooler.
Click Start to restart the Print Spooler. Then click Restart
Click OK
Hope this helps!
Thanks!! - See more at: http://hpanswers.blogspot.com/2008/10/cancel-and-delete-stuck-print-jobs-in.html#sthash.QD3KNI9q.dpuf
Jul 01, 2014 | HP LaserJet 4200 Printer
Afetr sending job to printer and decide not to print it. how do I cancel the job?
Open the Start menu and click on 'Printers and Faxes' or Control Panel>Printers in Windows 7. Right-click on the printer and click 'Open', this will display the print qeue, you can right click on print jobs and cancel them, pause them, or restart them.
Aug 22, 2011 | Epson Office Equipment & Supplies
I would like to cancel a print job without losing all of my memory card picture selections. Seems rather silly to lose all your selections if something goes awry with your printer output.
If you are using Windows, you can cancel a print job by opening your Start menu (usually the bottom left corner of your screen) then open Devices and Printers or Printers and Faxes depending on your version of Windows.
Double left-click the name of your printer
Right-click the name of the print job you want to cancel and select cancel print job or right-click a blank part of the printer box and select cancel all print jobs.
Apr 12, 2011 | HP Photosmart 3310 Printer
I cannot cancel a job in my printer
Hi, if showing, right click printer icon on bottom of screen. Menu if showing, click jobs waiting.
Right click on the work you wish to cancel, menu click delete, that should clear the box of the print job.
Alternative. Click Start/Printers & Devices/Right Click Default Printer/Click Properties/Click See Whats printing/Right click print job menu/Click dropdown Delete.
Mar 24, 2011 | Dell 1700 Laser Printer
Hello
Click the "Start" button, then click "Control Panel."
Double-click the icon labeled "Printers" or "Printers and Faxes."
Find the icon for your active printer and right click on it. Click "Open."
You should be looking at the print jobs list. All of the current and pending print jobs should be listed. If you just want to cancel one or more specific jobs, right click each job you want to cancel and click "Cancel" on the menu that pops up. If you want to cancel all of the current and pending jobs, click the "Printer" menu at the top of the window and click "Cancel All Documents."
You can get help from Microsoft official web site on this issue Click HERE
Hope it helps, if so do rate the solution
Dec 18, 2010 | HP Office Equipment & Supplies
Hi, I just need to cancell a print job. It must be so simple, but I can't discover how! I have a CLP-310 purchased May last year.
(If your operating system is Windows) Click "Start" then, "Printers and Faxes", now in the Printers and Faxes folder, double click the Printer's icon, again on the new windows, click "Printer" menu and then click "Cancel All Documents" again "yes" and close all the windows and programs.
Turn off the printer and turn back on after a couple of minutes. If this doesn't clear the print jobs, repeat the same procedure and restart both the computer and the printer. This will definitely cancel all the print jobs/queues.
If you need further help, let me know with a little more details.
Good luck.
Thanks for using FixYa.
Sep 25, 2010 | Samsung Office Equipment & Supplies
I tried to cancel printing jobs once in progress and had no succe
Printers will hold the documents in the memory of the printer. Windows holds the documents until they are received by the printer.
Go to the printer and cancel the job, then open the printer by double clicking on it in Printer and Faxes (if in XP) and cancel the document from the menu while the document is highlighted. (document, cancel)
A trick I have used is to remove the paper from the printer, wait until the last sheet is printed and turn off the printer. Windows will pop up with an error that includes cancel the print job.
Jan 23, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Sent too many labels to printer - need to reset
As the previous expert has stated, with the printer paused, press the cancel key to cancel the job. One thing to note, is depending on how your software sends the print jobs, you may say print 1000 labels, but the software sends it one at a time, so basically you have 1000 print jobs in the printer. If you pause the printer, press and hold the cancel key. Hold it for about 2 mins. This should clear the buffer.
Apr 21, 2009 | Zebra Z4Mplus Label Printer
Need to cancel a printing project
If you are using windows go to the start menu. Go to settings, printers and faxes. Open the printer window. Highlight the job and from the menu click on document and then clear. Reboot your printer and you should be good. If you cant clear the job disconnect the printer and try again. Rebooting will help the computer is all else fails.
Nov 25, 2008 | Office Equipment & Supplies
How can I delete pages from the Brother 210C printer that I do not wish to print^
For Windows XP - click Start, Control Panel, Printers and Faxes
Click on the printer to open up the printqueue. To cancel a print job, right-click on it and click cancel. To cancel all print jobs, click Cancel All Documents on the printer menu.
More information can be found on this website (this should work for any printer): http://hpanswers.blogspot.com/2008/10/cancel-and-delete-stuck-print-jobs-in.html
Nov 10, 2008 | Computers & Internet
OKI C6100n Laser Printer Logo
88 people viewed this question
Top OKI Office Equipment & Supplies Experts
Timothy Van Der...
Mike
CheckitRight
CheckitRight
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
