Question about Kenmore Elite 44173 30 in. Electric Cooktop
My Kenmore Range had theoven and stovetop locked symbol on it how do i unlock it
Posted by kendrickmich on
Anonymous
  • 5 Answers
Either hold down the 'Unlock' button or if the little red pad lock symbol is lid in the main display hold the 'Oven light' button for about 7 seconds...
Posted on Jan 26, 2010
  • Tony DiNicolas Jul 09, 2012
    that does not work any other directions?
How do I unlock the cooktops on Kenmore Elite Electric Range model #C970-440935
Clear the lock mechanism -- as indicated by the DOOR LOC light -- by pressing and holding in the oven door light switch for 20 to 30 seconds. While the switch is depressed, the latch motor will gradually withdraw the lock, allowing you to open your oven door.
Oct 03, 2018 | Kenmore Cooktops
How do I turn off the "key" icon on screen display Heartland Stove/Oven ?
The key is a lockout symbol. It appears when you set the oven to child lock mode ( Stops kids from opening the door and getting burnt) or when the oven gets over a certain temperature. (Stops you getting burnt) If you from have the instruction manual, it is xa bit difficult. You usually have to npress and hold 1 or more of the buttons in for a few seconds to unlock. I'm not sure which ones on your oven.
Jan 02, 2016 | Heartland Appliances 30 Inch Dual Fuel...
Where can I buy the stovetop burner gaskets?
  1. Gaggenau Range/Stove/Oven Parts - RepairClinic.com
    www.repairclinic.com/Shop-For.../Gaggenau-Range-Stove-Oven-Parts Huge selection of Gaggenau Range/Stove/Oven parts in stock. Same day shipping. Open 7 days a week. ... Door hinge, top/bottom. OEM Part - Manufacturer # ...
Jul 11, 2015 | Gaggenau Cooktops
What does the F93 code mean and how do we fixt it
i know that it can be very difficult to have issues with your oven. the f93 on this model of kenmore range indicates that you have a problem with the oven door lock assembly (see image below). this can be caused by a failed oven door lock assembly, a wiring failure or a bad electronic oven control board.
i recommend that you unplug the range and check the wiring between the components first. you can remove the upper back panel of the range to access the electronic oven control board in the console. you may need to remove the lower panel to access the door lock assembly on the back of the range. the image below shows the wiring diagram and other information that should help you check the wiring connections. check for a mechanical binding of the door lock assembly as well. if the wiring connections are okay, you will likely need to replace the oven door lock assembly. if you need further assistance, please reply to this thread. thank you for using manage my life.
May 23, 2015 | Kenmore Elite 30" Slide-In Gas Range White
I can't unlock the stove on my kenmore ceramic cooktop
I was cleaning my range hood and leaning over I somehow set the lock on the cook top. How do I unlock it?
Sep 08, 2013 | Kenmore Elite 44173 30 in. Electric...
My Miele 500 stovetop is locked, how do I unlock it?
just under the lock light you should be able to press and hold with your thumb for about 5-10 seconds and it will reset. You may need to place your thumb directly on the lock light or just below it and hold it to unlock it.
Hope this will help you. Good Luck.
Jul 18, 2011 | Miele Cooktops
Hob lock
gud day,the key symbol is the lock try to unlock the unit by touching the sensor,or check the manual how to unlock.
Jan 26, 2009 | Neff 23 in. T1443 Electric Cooktop
Kenmore Elite 44173 30 in. Electric Cooktop Logo
1,353 people viewed this question
Top Kenmore Cooktops Experts
Michael Thomas
Michael Thomas
jdthefixer
k24674
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
