Reddi heater 155 owners manual?
Reddi heater pro 155 owners manual? plug in, fan starts for 3 sec then unit shuts down. Getting fuel no ignition.
Posted by djdinwiddie8 on
  • Anonymous Mar 18, 2014
    find cd cell location
Frank Bryant Wetzel
  • 456 Answers
If this has a hot surface igniter, can you see it glowing? If not the igniter could be bad or the control
board for the igniter is baed.
If you are able, remover the igniter and hook it up to a 110 outlet, if it glows the problem is in the board.
If it has a board, follow the incoming power to line 1
and line 2. You will either have to splice the two leads
from the igniter into L1 and L2 or get a special spade
connector that can hold two leads on each terminal.
Plug unit in, glow coil should glow and unit should run
thats assuming you have that style of unit. Do not
attempt to do this unless you can safely perform this.
If you know of an electrician he can do this.
Posted on Jan 19, 2010
Fan comes on glow plug lights up but no flame.3 sec. fan shuts down.Have clean all lines, tips everything. Model 60 Reddy used very little in ten years.
this have a flame controler, if the flame didn't goes on in few seconds the unit automatically stops. back plug and start again, if not star after tree times check the flame control thermocuple, or get the unit in service to fix it.
Feb 14, 2010 | Reddy R60A Utility Heater
150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... www.desatech.com Thank you
Jan 28, 2010 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Reddy pro155 runs for 3 to 5 seconds
Reply with the correct model number. "Pro 155" designates a series. We need to know whether you have a heater with a spark plug or a heater with an ignitor (glowbar).
Feb 01, 2009 | Reddy R155D Utility Heater
I have a Reddy heater pro 155.
Check all of your air filters but most likely it's the CAD flame sensor.
Jan 22, 2009 | Reddy R155D Utility Heater
Igniter lites up fan kicks on and within 5 sec shuts off
Dustin, The ignitor only glows for 5 seconds, just long enough to ignite the fuel. The heater is shutting down because the photocell does not see the correct flame color.
Since you say "comes on for 5 seconds", I can only assume that there is a flame. You do not specify a lack of flame. I am also assuming that you have had the heater running this heater season and the problem just started.
YOU must find out if the problem is fuel delivery related or electronics related. Start by checking the pump pressure.
Follow these troubleshooting tips
Dec 21, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
I have a Reddy heater Pro 155 that will not start up
You can refer to this manual: http://www.bealsmotor.com/Desa%20Hot%20Surface%20Manual.pdf
They have a detailed troubleshooting guide. You will need a multimeter and some electronic experience for some of the tests. I hope this helps!
Nov 25, 2008 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater will not ignite flame
Please answer the following questions. There are several folks on the board that can help but we need to know some vital information so we can get started. Answer these, if you can:
  1. Which Pro 110 do you have. We need the exact model number. Pro 110 is a series of heaters.
  2. Does the heater have a spark plug or a glowbar (HSI)?
  3. When the motor runs is it pumping fuel?
  4. When the motor runs is the spark plug firing (or glowbar glowing)?
Nov 13, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heating & Cooling Logo
205 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
