Hi what is your mobile model?? if its nokia and if you forgot your privacy code/security code then try default code "0000" or "1234" and if it still does not work then try with master reset code to reset your mobile..try Unlock-Free.com to get master reset code to reset your mobile..
go to menu then click settings, security, change security code, type 12345 (default security code). after this step the phone will ask you to enter a new code after this, you will be asked to verify the code (need to retype your new security code then) then, your code is changed.
to activate the security code for your phone to use:
1. go to settings 2. choose security 3. choose security level 4. choose phone 5. restart your phone
after the restart, you will be asked to type first your new personalized security code before you can use your phone.
Hello Bo Duke, If one radio won't walk to the other my guess if that you have the Privacy Code function set up incorrectly. The privacy code function mutes the radio unless it receives a signal from another radio transmitting the same privacy code. If Privacy Codes are turned on for Radio A but not turned on for Radio B then you will be able to transmit from Radio A to Radio B but not from Radio B to Radio A. If Privacy Codes are turned on for both radios but each unit is set to a different code then neither radio will be able to talk to the other. Make sure that the radios are both set to the same privacy code or that the privacy code function is turned off on both radios. You can find more information on how this function is set in the radio's Owner's Manual. Hope this helps! Ken "Go Ahead. Use Us."
