Question about Yahoo Messenger
You may hear drop outs or poor sound quality in this call. Your Internet connection currently has reliability problems, perhaps due to a weak WiFi signal
  • Anonymous Jan 22, 2010
    Thank you for your answer. But my internet connection is good (3 HSDPA Fastest). I want to know how do I improve my WiFi signal ?
Keith Fox
  • 641 Answers
Like it says, you need better internet connection for better quality voice messages. just use text to instant message.
Posted on Jan 22, 2010
  • Keith Fox
    Keith Fox Jan 22, 2010
    point your antenna's towards each other, or you can try building a paraolic wifi antenna booster out of paper and foil to turn it into a directional antenna.http://www.instructables.com/id/DIY-WIFI...
    Any metal objects such as a filing cabinet will cause interference of wireless signals because they run on radio bandwidth.
5 Related Answers
Anonymous
  • 1383 Answers
SOURCE: you may hear .. .. . . .
you have to change your channel type in your wi fi router.
For that access your router with following link
http://192.168.1.1 or
http://192.168.0.1
if you have belkin router
http://192.168.2.1
type user name as "admin" and password is "admin" or blank or "password"
then go to wi fi ->advanced setup chang channel type 4 ,6 ,11
change chanel type 1 by 1 and check signal strength.
everyt time save settings and restart both computer and router after save settings.
thern check signal strength.
Thanks for using fixya.
Please rate this solution if it helps.
Posted on Jul 23, 2009
micky dee
  • 3015 Answers
SOURCE: You may hear drop outs or poor sound quality in this call.
Probably out of your control, if you have a strong internet connection.
I often get this message chatting to contacts in Asia Pacific in rural areas.
It can make voice calls a bit hit and miss and the script can be a bit jumpy.
Making the setting via 'Proxy' can be succesful in some situations.
Posted on Aug 29, 2009
Anonymous
  • 88 Answers
SOURCE: yahoo voice chat problem
You should remember, this is a fee service, so the quality is going to eb a little poor. Some of the things to increase, would be to eliminate all other softwares from running that would use the wifi or network connection. And have the person on the other end do the same. Of all the IM pc to pc chat/talk programs, Yahoo, seems to have the worst quality. if it is for voice only, I might suggest Gtalk, it seems to have the quality consistantly.
Posted on Sep 11, 2009
Anonymous
Posted on Jan 31, 2010
carloadrian
Carlo Adrian Canon
  • 571 Answers
This is a message that yahoo messenger usually tell the users when it detects a low internet connection. You are right with what you have mentioned about the weak wi-fi signal.
I have been receiving the same message because of my wi-fi signal but so far so good. I never have any problem with the quality of the sound in the call or any disconnection of the call except for the sloppy webcam. But, I understand the problem because I really do have a low signal at home.
Posted on Apr 02, 2011
You may hear drop outs or poor sound quality in this call. Your Internet connection currently has reliability problems, perhaps due to a weak WiFi signal.
Apr 02, 2011 | Yahoo Messenger
If your network provider is providing you enough bandwidth you might need to check the following:
If you are using wifi:
Wifi channel is the optimum one.
You are close enough to the router.
Try with a cable and see if you have same issue.
If you do have the same with the cable, contact your network provider.
Kind regards
Mar 05, 2011 | Yahoo Messenger
Check your internet connection.
You may need to reset your modem and router. If the problem persists, your signal may not be strong enough from your location.
Feb 07, 2011 | Yahoo Messenger
Due to your low internet speed, the message shows. Or try restarting the modem.
Thanks for joining us.
Have a good day.
Jan 07, 2011 | Yahoo Messenger
I have a belkin wirelss router for the lap tops. but i got a desk top computer which it is hooked up to but is causing a low wifi signal when i am using a messenger and when i have the video call on a...
1. this possibly due to 2 things
a. You have the desktop to far from the wireless router.
b. You may have an issue with decreased bandwidth by using the video calls.
May 30, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Yahoo voice chat problem
Sep 11, 2009 | Yahoo Messenger
You may hear drop outs or poor sound quality in this call. Your Internet connection currently has reliability problems, perhaps due to a weak WiFi signal this massage apear to me when use voice chat...
Aug 28, 2009 | Yahoo Messenger
Jul 04, 2009 | Yahoo Messenger
Yahoo Messenger Logo
481 people viewed this question
Top Yahoo Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Mike
Barbat Nae
Barbat Nae
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
