My Genius G-Pen F610 will often fail to recognize the pen unless I'm 'clicking' with it by actually pressing down. The cursor won't follow if I simply move the pen over the surface of the tablet without touching it. I've tried replacing the pen battery, rebooting the computer, trying it on a different computer with a different OS, reinstalling the driver, and none of it seems to have any effect on this problem. Is there anything I can do?
For me, the Tablet PC Input Service wasn't started. The pen would only work inside the drivers pen setting window, and once it lost focus, it wouldn't work.
I checked the services and that one was set to manual start, so I started it, and then the pen worked fine. Also, I set it to automatic start.
Hi, i browsed the Net in three languages to find the solution for this problem but nothing helped, then, accidentally, i bumped into the solution that helped me. I tried everything the same way you did but nothing helped. Since I use the russian version of Windows I do not know how these options might be named in english, but I think you'll understand. In Control Panel there is, as you know, the setup for pen and tablet input (with a picture of a pen) - in it there is a setup for Gestures (the middle one) - in it i disabled the gestures a long time ago. But today i tried turning it ON and went for training of these gestures (the option in blue letters at the very bottom) - and during the training my pen started hovering normally again after half a month of this problem. So I left the gestures enabled after completing the training and it still works fine. Hope it helps you,
SOURCE: Replacement Pen for G-Pen F610 isn't working very well.
nomally happens the 1st time you use.
log off and back on again.
otherwise reset ... it should work next time you boot up.
anytime I touch a pen to the tablet it zooms in , how can I stop it from doing this?
