Question about Logitech X-530 5.1 Surround Sound Speakers&Subwoofer - 970114-0403 Computer Speakers
No sound from speakers after disconect &reconect from computer.x-530 sound blaster
Posted by gkastoun1 on
Brian Manuel
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 189 Answers
Start up cd redo if not go to website for download and if not go to your computer makers website for a possible patch
Posted on Jan 18, 2010
Hi i have creative sound blaster 5.1 surround sound. 2 rear, 2 front, center, and sub woofer. i am not getting sound out of the rear speakers. does this box have the capability of running all the speakers...
Your Dell supports up to 7.1 surround sound...I'm guessing you have something hooked up incorrectly. If not, make sure your drivers are up to date on the sound card.
I bought some surround sound speakers 3-5 years ago and they recently have not been working properly. First I have to make sure the external sound card is plugged into the computer so it will register it,...
first did all of these speakers work together at any stage
if not you will have to get yourself an external sound card possibly a usb portable/removable sound card
I purchased a new desktop PC with Windows 7, & I'm trying to find out what the correct connection is for the Logitech X-530 Speakers is. That is, can I get all the 5 speakers to work at the same time?
It depends on the sound-card in the PC.
The "back-left" and "back-right" speakers require special connections to the sound-card.
The "left" and "right" and "centre" speakers are connected to the "main-stereo-audio-out" on the sound-card, as per normal.
My New sound card did work, but i had to Format my comp.
CAREFULLY remove your sound card and then try to boot up.
if it does not boot up then your computer has a problem and you need to consult your MFG.
if it does boot up then check the specks on the sound card and check if it is compatable.
if it is compatable, make shure that the contacts are clean (use a compressed air cleaner), and that the sound card is not damaged, then reconect (with the computer off).
______________________________________________________
In the way of only one speaker working, you probably have a loose connection; bad cable; or a bad speaker.
1helpful
How to connect 5.1 speakers to a notebook
yes it will :) if it has 6 female ports (the normal 3 + 3 extra) it will work just fine :)
Logitech x530
I have had this a few times with customers. You might want to check if the sound cards front speaker ports are working correctly. If the card is working, the problem might be with your right front speaker, ckech that it is working. You might also want to check the settings in control panel; this has helped me a number of times.
cheers
The model #under my speakers is X230-07 but a picture of these say they
Hi Arty, if you have a nice sound card, like Creative Live, or Audigy, or Sound blaster X-fi, use your cables that came with the x-530 depending on the cables provide, the cables are well identifid by colors, put in the same way in your computer, and of course, you need to make adjustment on control panel, in sound setting to use 5.1 computers, this may do the trick
Carl
3answers
3 of 5 speakers not working.
Go into your computer audio system and make sure you are on you are not set on stereo
Top Logitech Audio Players & Recorders Experts
Marvin
Marvin
Muzahura Frank
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
