One older kenmore warsher, Model num 110.14202300, wash and rinse are ok, but does not drain or spin. After one wash procedure or sole spin operation, the clothes are still very wet (likes just after rinse). during the spin, can hear the noise, seems the inside tub rotation is ok. what's the problem or what should I do?
thanks
The clothes too wet after spin cycle tells me that the water ump is functioning. If it wasn't, there would still be lots of water in the machine when the cycle ended. These Kenmores have the water pump mounted on one side of the electric drive motor and the transmission, drive shaft, and agitator on the other side. The transmission is fastened to the motor by a "coupler", a three piece assy that often breaks. This common failure allows the machine to complete a cycle, however, because of the broken coupler, there is no drive to the tub and no spin or agitate. The clothes seem wet because the spin motion is supposed to provide the force to extract the excess moisture. Leave the lid open and verify that there is no agitate or spin.(During spin cycle use a pen to press down on the safety interlock, a small opening on the the of the machine, toollow the unit to spin with the lid open). If you verify this, flip the machine over and locate the coulper on one side of the motor. One side will be cracked along the shaft. Sears parts stores carry the coupler in stock. ($18.50) Hope this helps.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
heatman101
