Sherwood RD-6500 Receiver Logo
Question about Sherwood RD-6500 Receiver
Would like to hook up two recievers to push all my speakers comfortably. I have a pioneer vsx d490 and a sherwood rd 6500. How wud i accomplish this?
Posted by reggae_76 on
Anonymous
  • 8,546 Answers
I think you mean Pioneer VSX-D409.
Since the two receivers are similar and capable of driving everything else in the room, I guess you want to treat one receiver like a basic amp, like for a passive subwoofer, right?
However, still guessing your intent...
The VSX is a basic 5-channel amp (5 x 100w) but only has digital multichannel inputs. It has optical and coaxial digital inputs and an optical digital output.
The Sherwood has coaxial and optical digital inputs and no digital output, but it has analog inputs, so it would be easier to selectively use any or all of its amplifiers, which are about the same as the Pioneer's (gotta read the fine print - Sherwood uses a 6-ohm load instead of 8-ohm to get the numbers).
Choose the one you like to use for the control (master). Run its Sub Out to the other receiver's AUX input using an RCA splitter to feed both input channels. Attach the sub to one set of front speaker terminals. Configure theat receiver for NO SUB so it won't steal LFE from theis channel. Designate the FRONT speakers as Large.
Setup would be tricky because you have to choose a volume setting on the slave amp and stick with it. It might get changed after you set the levels and negate the setup efforts. OTOH, you would have the flexibility to change it independently if desired.
My $.02... If subwoofer power is all you need, why not just get a nice Carver 2-channel amp on eBay (2x100w would suffice), bridge it to 200 watts and blow the house up, figuratively? Then you could redeploy or sell the unused receiver.
Posted on Jan 19, 2010
What are the codes for the RCA RCU600D to program a Sherwood RD-6500 reciever
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
2helpful
I set the levels for all the speakers where I want them to be set at. But when I turn the unit off I lose all the speaker level settings and have to reset them
Some recievers have both a "power switch" and a "stand by" switch. Here is the difference.
"Power switch" eliminates all power input and most likely the memory in the unit too just like your stating in your situation.
"Stand by" switch shuts down all major components but keeps a small ammount of power to the unit to conserve any stored settings
1helpful
1helpful
Pioneer VSX-815 speaker wiring
You can hook them up either way, the banana jacks are good for hooking two speakers to one terminal (ie one through the botton, one banana) but the electrical connection is the same either way. Sometimes the banana capable jacks are on speakers A and speakers B, and the surround don't accept banana plugs, your stuck with how your reciever is wired.
RD-6500 Sherwood amp
What model RC? Doesn't its manual give some clues?
3helpful
2answers
Connecting a sub-woofer to Pioneer VSX-453 surround reciever
I got the same issue. But, I go ahead hooked it up two banana plugs on teh VCR outlet. It works fine on my Cerwin Vega Sub.
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Steven Brandon
Steven Brandon
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
