If you have a whirlpool/ kenmore dishwasher and the clean light is
flashing 7 times then pauses and then repeats, it is a problem with the
heating circuit.
follow this keypad operation: push the high temp wash, air dry, high
temp wash, air dry. this will put the unit into a service mode and it
will run a short diagnosis cycle. after it gets done, about 5-7
minutes, then it will reset and allow you to use the unit again.
make sure the water is hot enough at your faucet at least 120 degrees, and the door is getting closed tight.
Thank you very much!!! I just fixed my dishwasher following your tips. Mine only blinked 6 times and has high temperature and heated dry bottoms but it worked.Good tip! ..................Lucy
