Televison & Video Logo
Anonymous Posted on Jan 17, 2010
Sharp AQUOS LC-26SH10U 26 inch LCD Television. Video input problems? No audio. I get a picture using RCA cables but nothing using coax cable. Also I have no audio. When I get a picture using the RCA cables I have some thin vertical lines on the screen. A Red line on the right portion of the screen and a few green and blue lines on the left portion of the screen. I would like to know which component board I would most likely have to replace? Thanks, Chet
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Jan 17, 2010
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2957454
Points
33084
You need to replace Main Board of TV to fix its issues, click Shop Jimmy to see an image of that board, call Shop Jimmy on 952-881-6492 or 877-881-6492 for main board availability as currently its out of stock.
Thanks.
1helpful
Sharp Aquos 32D64U LCD HDTV. I need help connecting and/or setting up an Ematic AT103B digital converter box.
Question edited for clarity and order, 'make model (what it is)'.
On the television remote you have to select the Source or Input. Each press will take you through the HDMI ports and all other signal inputs like co-ax. Your LA channel is likely via the co-ax indoor aerial.
Support Details LC-32D64U
Sharp Electronics https://www.sharpusa.com > Support
Owners Manual. LC-32D64U ' LC-37D64U Operation Manual. DownloadOpens in a New Window. FAQs. These are FAQs related to your product. My TV is not powering on.
Sharp LC-32D64U 32" 16:9 AQUOS HD 1080p LCD ...
B & H Photo Video https://www.bhphotovideo.com > ... > Televisions
The LC-32D64U 32" 16:9 AQUOS HD 1080p LCD Television is an ultra-slim and light LCD TV, that easily enhances the decor of any media room.
I have a Sharp Aquos. A video cable is connected to interface EXT-4. Video is working fine. Which audio interface can |I use to get audio too and what do I have to set in the TV menu?
There should be RCA type audio input connections near the ext-4 video cable. One red and one white. If you connect these cables you won't have to do anything in the menu.
What cable do I need to set up the HD and where do I plug it in? All the ones I lookes at have a rectangular end and I don't see one on the like that on the TV. I am using the 2 scart sockets for cable...
Any of these will work.
ANTENNA IN: UHF/VHF 75 ohm Din type (If in HD Broadcast)
EXT 1: SCART (AV Input/Output, RGB Input, TV Output)
EXT 2: SCART (AV Input/Output, Y/C Input, AV Link)
EXT 3: S-VIDEO (Y/C Input), RCA pin (AV Input)
EXT 4: RCA pin (Vomponant Input)
PC INPUT: D-sub 15 pin (ANALOG RGB), 3.5mm Javk (Audio Input)
Service Manual can be found here: http://www.givemefile.net/smanuals/lcd_tvs/sharp/file/45437.html
32 inch LCD sharp tv switches audio from mono to sterio every 4 to 5 min
When you are connecting this television to a signal source with a coax cable this happens. The solution is to connect with an RCA/composite cable instead and utilize the television's inputs instead of using input tv.
1helpful
I BROUGHT A USED SHARP AQUOS TV I CAN'T GET IT TO SEE MY CABLE KEEP SAYING FAIL TO RECEVE BROADCAST
How are you connecting it to cable tv?
If you are using a coaxial cable to a cable box you have to turn to channel 3.0 with a Sharp remote by pressing 3.0 enter the dot (.) is down by the 0. There is a way around this if you don't have a Sharp remote. You can go into the menu and complete a channel scan. If the model you own is the one pictured then you should have the coax cable connected where it says analog if you are connecting to a cable box this way.
If you are using composite, component, or hdmi cables you press the input button on the television and pick the right input. It is recommended that you do not use the coax cable anyway unless you do not have a cable box. There is an input button on the television and on the remote.
2helpful
Hi, I bought an aquos lc-30hv4u and it has no rca jack etc, only two plug ins labled display input 1 and 2. I am guessing its just a pc monitor. How would I use it for cable tv video games etc
There are lots of inputs on the back behind the cover. Three inputs (1, 2, 3) have an S-video, composite video (A/V) and component video jacks. The cover will come off if you press the two top hook at the top of the cover. Then rotate the cover towards you. There are also a DVI-D port and 2 coax (antenna in) jack. The tuners included are for NTSC (analog OTA) and CATV (analog cable). The front of the PC (VGA) and a S-video or composite (A/V) video input (called Input 4).
Composite and component video jacks are all RCA jacks (as are the associated audio jacks for the input). Composite cables uses three RCA plugs on each end - yellow for video, red and white for Right and Left audio. Component video cables have three plugs on each end that just carry video (red, blue and green); the audio is wired separately with just 2 RCA red/white plugs. Match your colors from the device out to the TV input.
Changing inputs can be done with the remote or the input button on the top of the TV. The input button is to the left of the power and Main Power buttons.
Connecting your game system, cable system and all will depend on the units. For the best picture, use component video cables for mose set top box. Some cable boxes have a DVI port - use that if the box has that option. If they do not have component video out, then use composite or S-video cables.
The owner's manual is available from Sharp as a pdf: http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx?downloadtype=ownersmanual . Use the drop down menus as follows > LCD TV, Model not listed, LC-30HV4U then click Search. The picture of the inputs are on page 10.
I hope this helps.
How do i connect audio from satellite receiver into sharp aquos tv
If you are using an HDMI cable the sound and audio will be in the same connector. If you are not then you must run an audio (stereo both L + R) cable from your satellite receiver to the audio input of your television.
If you are using a S-Video cable it only carries the picture and not sound.
In that case it also requires an audio cable as well as a video cable.
Connection problem
The best hook up for this unit is to use the hdmi if your samsung box offers hdmi output. The panasonic vcr should be hooked to any one of the composit video inputs with the yellow video cable and the red and white audio cables. If the vcr does not have composite output then use a rf (coax cable) to antenna a input and put the tv on channel 3 or 4 as vcr is set for.
Sharp Aquos LC46D64U
No reason for the audio not to work on the RF cable. Check under menu and option and make sure audio is set to fixed and not variable.
Sound, but no picture
The hdmi inputs on this unit go directly thru the main digital pcb. and the component inputs feed thru the av pcb then to the main pcb. If the composit hook up do not work and hdmi inputs do work the unit has a bad AV pcb.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
