Dishwashers Logo
Posted on Jan 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need a Miele dishwasher part - it's the part with the stainless steel ball in it.
David
Level 2:
  • Expert 177 Answers
  • Posted on Jan 18, 2010
 David
Expert
Level 2:
Answers
177
Questions
0
Helped
213085
Points
452
That is the non return valve which sits in the sump of the unit. you will have to purchase this from Miele spare parts. No other place sells Miele parts.
Miele dishwasher 892 intake/drain light blinking
The intake light blinking error can be caused by several different problems and may take some pains taking effort to figure it out. There is some helpful information about Intake/Drain light flashing. http://www.techanswerslive.com/appliances/miele-icognito-dishwasher-service-mode-error-codes/12
Can I replace the front panel from black to stainless steel?
I'm pretty sure Appliance Art can help you. They sell stainless steel panels for dishwashers that can have the front panel replaced and they sel faux stainless for the dishwashers that don't. They were just on DIY network, HGTV, and the Today show. www.applianceart.com
1helpful
Miele dishwasher finishes the cycle with water in the bottom and the dishes not clean
In the bottom of the dishwasher you have a filter. under the filter is a non return valve. it is a one way valve that keeps the dirty drain water from draining back into the dishwasher. if it is dirty or broken, the dirty water that your machine drains out, is running right back in as soon as the drain pump shuts off. this will keep happening and your dishwasher will just spray the dirty water back on the dishes over and over again.
to get to it, you will need to get the water out of the machine. if you have a wet dry shop vac use that. if not, you can bail it out with a cup, and soak the rest up with a sponge. remove the lower spray arm by pulling it up. remove the filter by pulling the handle in the direction of the arrow. lift the filter out of the way. get the rest of the water out of the sump. on the left side of the sump, you will see a silver wire bail holding the non return valve in. flip the bail towards the center of the sump. pull up and out on the non return valve. it has a rubber seal and a stainless steel ball inside. any debris between the seal and the ball will keep the valve from closing all the way, and allow the water to drain back. you can order a replacement if needed, directly from miele. 1800 842 7231.
I need to replace the thin white door panel on a MIELE G832SC touchtronic turbothermic dishwasher
you want the replacement to be white as well? Check out ApplianceArt.com, they have over 200 different panel options including stainless steel, black, and white.
My Miele Inspira has started squeaking when it runs.
Hi dear.It sounds like your machine have faulty bearing on main wash pump.That bearing can worn out it self or there is a leakage on impeller housing,that leakage can cause harsh chemical to get in to the front bearing of motor & damage it.Your machine should be under warranty,call Miele service in your country.I hope that helps.Thanks.
Is stainless front panel available
you probably can find a stainless solution at www.applianceart.com. I know they sell stainless panels and also stainless steel foils that can be applied.
1helpful
2answers
I don't have a problem, but would justy like to
Hello. Not all dishwashers have multiple panels which you can interchange. However, you always have two other options. One is to paint the white cover with stainless steel spray paint.
You can do this yourself with spray cans available from home depot, or you can remove the door and take it to an autobody shop to have it professionally done.
you can also have a piece of stainless sheet metal cut to size at a metal fabricating shop and use a construction adhesive to attach it to the front of your dishwasher, using stainless outside corner trim to finish the job.
2answers
Missing Panel, Handle & Manual
The Incognito series is made to have a cabinet panel installed on the front - as to blend in with the cabinets - no handle - no panel - cabinet front panel with the cabinet hardware attached
Top Miele Dishwashers Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
