Whirlpool washing machine wont stop all lights flashing at once. cannot get clothes out and its full with water. Stops when switched off at mains but door wont open.
Check your washer plug to see if the connections are
tightly
screwed. Next check your filter if you haven't for long.
Remove
the 3 screws at the bottom of the front panel under the
washer door. Your filter door will be light brown. If you find a hose
there it is to drain out excess water (water that could not be drained
by your pump) After you hv drained unscrew the cap and
remove all the junk inside. Have a large plastic bag to catch junk and
water. Refit carefully after cleaning out. If not solved, something
shd be blocking your pump, check this out.
While the machine is on press "end of cycle" for 3 seconds, then wait
for 2 minutes to try the door. Try this again if it does not open, this
is the child lock program - to lock and unlock; it is the same
procedure.
How abt a nice rating
for the free help? Thnks
