Question about GE Ovens
Aqua GE Wall Oven SN10729 (Can't find a part number) 1950's-60''s
My mother has an old GE Electric Wall Oven and matching cooktop. I believe the heating element is the problem but don't know where to find a replacement.
I have photo's of the oven and heating element. I was unable to find a model number, but did find a Serial Number SN10729 if that is helpful.
Posted by TammyButron on
vince
  • GE Master
  • 1,234 Answers
From the serial # it was made in september the second letter N is either 1956 or 1972.
take a look at this site it'll lead you to ge heating elements
see if there is one that resembles your's.
then call them. they are very helpful and may be able to tell you where the model # is. ask if what you're seeing might fit.
here's the link...
http://www.appliancepartspros.com/ge-wall-oven-heating-element.html
Hope this helps a little.
Happy New year
Posted on Jan 02, 2018
5 Related Answers
Anonymous
  • 878 Answers
SOURCE: Electric Oven doen't heat
cdkd, there should be a TC0, on the back of the oven. Thermal cut out. You want to check to see if it is open. You will have to pull the oven out enough that you can remove the back panel cover and check it. The lower and upper oven should have one. It's a very cheap part to replace. If this TCO fails, no heat. Check this first before buying a new board. Catriver..post back.
Posted on Dec 27, 2006
Anonymous
  • 750 Answers
SOURCE: Oven heating element
Hello rvready
Welcome,
You said, We have an OLD (1950-60) Frigidaire wall oven, model # RBG-94. Bottom heating element has gone out. Oven is still in good shape so we'd like to be able to find an element replacement, but have had no luck finding one.
unfortunately,
I am not able to find this part either.
Anywhere. This oven is to old for parts. But most important is that it is causing you high utility rates!
Today's appliances save you the arm and the leg that such an old oven is costing you.
You have no idea how it is sucking your money out of your pocket!
It is unfortunate, that no one told you about this years ago!
You payed for more than one oven with your utility bill if you had it since it was new. My advice is do not put good money into bad!
Shop for a new one and see your bills go down.
my wife was telling me to replace the air and furnace for 7 years and I said, it's not broken. But it was over 20 years old. She was right, cause the new one saved me $100. a month!
That means I threw away $7000. in 6 years with my old world attitude.
Yes I am old fashion and always fix it!
But after 25 years of marriage. i finally realized she is a good evaluator and I was a fool to not appreciate her gift for all these years! And out tons more money than I told you about!
Hope I saved you some bucks with my real life stories!
Don't tell your wife!!!
Huuum
Posted on Oct 17, 2008
Anonymous
  • 405 Answers
SOURCE: Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
Posted on Dec 27, 2008
kachbibi1
Bill Dickerson
  • 979 Answers
SOURCE: Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Posted on Jan 30, 2009
dr260
  • 177 Answers
SOURCE: wehre is model number located on viking oven?
It is usually on the stove at the bottom of the oven door. you might have to remove it to read it properly
Posted on Sep 18, 2009
I have a 1950's GE pink/beige wall mtd w/ matching cooktop...I can't find the model # label on the wall mtd oven ? where is it located ?
Mine is a slightly newer model (1960's pink) and out of the wall at the moment so we looked last night. The nameplate is located just below the opening to the oven, in the center, open the door and look down, riveted on. Maybe yours is there too?
Sep 22, 2010 • GE Ovens
2answers
I have a 10 year old GE profile dbl wall oven that I love BUT with a new Stainless fridge, cooktop and dishwasher the wall of white oven is a glaring mis-match. The oven doors both have exterior white...
Go to www.applianceart.com and check out their instant stainless material which is perfect for refacing your existing appliances and getting the stainless look you want without the stainless pricetag.
Contact these guys with any questions you may have.
NEED PARTS FOR OLD WALL OVEN...AMERICAN CROWN
Please call me with your model number and I will do my best to find these parts for you. 9728590929. Thanks, Ella
2helpful
Ge wall oven old!
here is a link that might help out.
click here
Choose your location from the link. A local service number is displayed. Get a repairman to visit the place, and then describe the problem; in this case the broken hinge. This should certainly work out.good luck. Please add your comments and also do tell me if you are located outside US.
Ovens Logo
Top GE Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Ekse
Are you a GE Oven Expert? Answer questions, earn points and help others
