I would suspect that the CD-Rom drive has gone bad. The easiest way to check this is to swap it out with a working CD-Rom drive. If the bios recognizes that one you have the culprit. If that is not the problem, I would then check the cables. If they are all ok, I would make sure the BIOS is updated. If none of these solved your problem, It may be a bad IDE or SATA port, or failing power supply.
