What are you trying to repair?What on the tractor is not working?Copy right laws prevent me from posting the diagrams but i can help you with your problem,i have access to the diagrams you need so let me know what you need.
Is your tractor a 4500?If this is not the right model i'll need to know exactly what it is, the serial number would help.
The seat switch gets its power from fuse number 5 in the fuse panel under the steering column.That fuse gets its power from the red wire numbered 0728 and is red in color.There is a fusible link that is bolted to the starter that feeds the key switch.Odds are if you have power to all of these points them you have a detective pto switch or mid pto switch[if equipped].Also you have a neutral safety switch and a park break switch involved with this circuit also,any one of these will keep you from getting power to the seat and the fuel shut off solenoid.The most common problem is a defective pto switch or a blown fuse to to a short in the wiring near the neutral safety switch[it is in a hole in the housing under you right foot when setting on the machine.Let me know if you need more help.
SOURCE: Need wiring schematic diagram for JD L130 lawn
You should price a new wiring harness,around $80 so there is not much reason to spend a lot of time trying to find shorts or open wiring.
i have no power going to the injectors or the safety switch under the seat
i have a John Deere 4500
What model is your tractor and what do you need to fix?Are you trying to install something and need to know where to pick up power?Let me know,i can help.
