Question about Mustek PVR-A1 32 MB Digital Media Player
Replacement Battery Mustek PVR-A1
Looking For A Replacement Battery Mustek PVR-A1
Posted by just4c1 on
5 Related Answers
Anonymous
SOURCE: mustek pvr h140
yeah, man, i did the same. cracked the glass, without damage to the screen, and then just made one myself, cutting it out from a cd-box and then glued it on :)
Posted on May 13, 2008
Anonymous
  • 22 Answers
SOURCE: Mustek PVR
Try Maplins, or a specialist electronic component supplier.
Posted on Jan 14, 2009
Anonymous
  • 4 Answers
SOURCE: HOW TO CHANGE THE MUSTEK PVR-H140 BETTERY
It is real easy to change the battery, I have done mine a few months ago
if you remove the screws from the back top and bottom (4) and remove the case
next remove the 2 small rubber strips from each side of the hard drive, then very carefully pull the connecting ribbon off the hard drive, this can be tight so gently prise apart with a screw driver,
once the hard drive is removed you will see some earthing straps just make a note of where these are located as you will need to put them back in the right place, they simply touch the hard drive,
now you shoud see the battery (very thin in a blue plastic case) you might want to remove the rubber proctective stuff just to make it a bit easier there is a simple pull/push connector
just unplug it and replace with new battery and reverse the procedure.
Dont panic if the unit fails to switch back on as mine did when i re assembled it
it was just one of those earth straps in the wrong place.
I hope this helps,
P.S I changed the battery on a unit I bought on ebay and i had nothing to loose
if you are unsure do not attemp the repair.
Posted on Jan 17, 2009
Anonymous
  • 10 Answers
SOURCE: HI!I FROM GREECE! THE BATTERY OF MY MUSTEK PVR-140
Try the website bargain basement batteries, they carry batteries for phones, cameras and laptops and probably for media player. The other choice is to contact the manufacturer and order the replacement parts
Posted on Dec 07, 2009
Anonymous
SOURCE: AC power jack came loose from the board
This happened to me too. Just unscrew the 4 screws, lift out the hard drive and glue it back down to where it was (2 little pegs will fit into two little holes on the circuit board. You can touch the contacts with a thin tipped soldering iron if you want to but you probably don't need to.Then close it up. That worked for me!
Posted on Jan 03, 2010
Dec 07, 2009 | Mustek PVR-H160 (60 GB) Digital Media...
Spares required.
Battery spec as per manual 1000m Ah x2 doesn't give the voltage but the charging addapter is 5volt 2.0amp.
George
Apr 24, 2009 | Mustek PVR-H140 Digital Media Player
Mustek H140
you can order a new battery from mustek in germany
I have got there email address at work i will post it here in the next couple of days
But I had the same trouble the battery would only last half an hour or so
I had to send 30 euros in cash !(due to horrific bank charges)
but went very smooth got it all sorted in about 2 weeks start to finish
now mine works fine
May 20, 2008 | Mustek PVR-H140 Digital Media Player
In my move i lost all my acessaries and instructions etc, for my PVR-A1 Personal media player
If this helps, you can download the manual from HERE
as for the accessories, you'll just have to buy new ones..
Apr 12, 2008 | Mustek PVR-A1 32 MB Digital Media Player
Mustek PVR
Apr 07, 2008 | Mustek PVR-H140 Digital Media Player
Mustek pvr h140
Feb 18, 2008 | Mustek PVR-H140 Digital Media Player
PVR H140 - Frozen on "initialize" screen. I've been looking for help for awhile.
Hi, If you haven't solved this problem, I would be interested in buying the Mustek for spares - let me know. [email protected]
Aug 10, 2007 | Mustek PVR-H140 Digital Media Player
Mustek PVR-A1 32 MB Digital Media Player Logo
Top Mustek Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Mustek Audio Player and Recorder Expert? Answer questions, earn points and help others
