Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sounds stop working after about 1 to 2 hours of viewing.
Sound is also changing between channels, commercials very high, regular programming very low when you have same level of sound. If you change channels the sound will come back and be normal for another 1 to 2 hours of viewing, except for high/low sounds, that continues as described above.
I am a Dish Network subscriber and live in Illinois.
Posted by bthorild on
Anonymous
    Novelist:
  • 123 Answers
We would be happy to help you with this. The volume levelingfeature that we have sounds perfect for this situation; it keeps the volumelevels consistent between programming and commercials and also prevents drasticvolume level changes when switching between HD and SD programming. The volumeleveling feature is supported by the following receivers: ViP 222k, ViP 612,ViP 722k, and ViP 922; the model number of your receiver is displayed onthe front in the lower left corner. Your receiver needs to be connected by onof the following: composite cable (green, blue, red cables), coax cable (singlecable with metallic tip), HDMI or optical devices that do not support Dolbyaudio.
Start by pressing the menu button on your DISH Network remote control, thenpress the number 6 for system setup then 7 for audio output. Once therehighlight the "Enable" option below Volume Leveling and press select.Once enable exit the menu by selecting done on the right side of the screen.
We hope this helps to get things set up the way you like it. Thanks forchoosing DISH Network!
Phillip Chang
DISH Network Customer Service Representative
Posted on Mar 18, 2011
Why does the channel up or down sometimes not work?
It sounds to me like you have a fault in the tuner circuit. I suggest you take it on for service.
Oct 23, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
Hello, My samsung ln82341w has sound problems. Two cable channels have no sound; 1 channel has crackling/static sound; and most of the other channels the sound will go out when the first one or two...
The problem isn't with your TV, its with the cable company.
Call the cable company, problem is most likely with your digital box or a signal problem.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Aug 22, 2011 | Televison & Video
I just switched to an HD receiver. The sound on the HD Channels is lower than the sound on the regular channels. How can I fix this? Dishnetwork has aready checked their end.
Some Sanyo TV's have a feature called Dynamic volume, this feature can be enabled by just pressing the dynamic volume button on the factory remote. We happen to offer a similar feature called volume leveling on our VIP 722k, 612, and 222k receivers. This is a recently released feature that will keep the volume even, during commercials or when changing channels. To access this press menu 6-1-6 and select enable under volume leveling.
Daniel Busa
DISH Network
Customer Service
Oct 03, 2010 | Sanyo DP37647 37 in. LCD TV
Sound cuts out when sound quality input changes on my rxv1700
Your HDMI version software and hardware will not work with todays version. The current version 1.3b is what works correctly (so far) IT can be upgraded to todays specs however, it's a preicey task for minimal gain if you are viewing any TV smaller than 50". The human eye cannot see the difference between 720p and 1080p on any TV 50 or smaller. That being said, if your TV has multiple HDMI ports, you can sidetrack this issue by connecting directly from the source, ie DVD, BLURAY, etc. then use optical or coaxial digital coaxial to the receiver. I know it's not the best news!! don't Blame Yamaha! it's been the recording industry and copyright protection issues that have overloaded product with "anti-piracy" software to the point you can't view it!. All receivers prior to 09' have multiple HDMI issues. Also, try setting your receiver to "Auto" in audio and running an analog RCA from the source to the receiver as well as HDMI, it may help, however, analog is much louder than digital, and I'm not sure if you can "offset" the volume level for analog in that receiver's settings. So, when you go to a commercial it could be unbearably more annoying than not listening to the commercial at all! Hope this helps.
Aug 15, 2009 | Audio Players & Recorders
Sound on my rca tv
I wonder if your problem with loud volume occurs primarily on commercial breaks, when you turn down
the sound and then, since the sound, for the program itself, is so low in volume, you have to turn it way
up again to enjoy the program?
If this is the case, and there are no other problems with the set, this may not be the set's problem, but the
fact that commercial material is broadcast at a higher volume than program material by some outlets, so
that while you are in the kitchen, during commercials, the sound of the commercial can still be heard.
Apr 18, 2009 | RCA Televison & Video
Low sound on my Vizio 50" plasma
Most of HD channel broadcast in 5.1 channel sound. Regular channel broadcast in 2.0 channel sound. You TV only have 2 speakers so you will expect the sound will be low compare with the regular channel.
Hope this will help!
Feb 04, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Direct TV DVR sound/no picture or pict. no sound
My Direct TV has no sound or picture but does show channel info at the top. Any help is appreciated.
Dec 13, 2008 | Directv (R10) DTV Receiver / 70-Hours...
Front Audio Video inputs not working
What model TV is it?
it may be you need to change the input to video 1 or video 2 to get those front jacks to work. if there is a TV/Video button on the front you should be set. If not you may need the remote control. Sometimes changing the channel to below channel 1 will give you that option.
Nov 20, 2008 | Televison & Video
Sound problem!!!!
Hi, new one on me but heres one thing you should do with that comcast box, un-plug the AC cord on the comcast box for about 1 minute, plug it back in and be patient while it re-boots, can take as long as 4-5 minutes, this re-sets all the logic states in the box, hope this helps.
Nov 29, 2007 | Televison & Video
Commercial skip/blackouts
Sounds like you're blessed to have a tv like that! Seriously: Some sets have settings that will cut down the sound during a commercial. Haveyou looked at your owner's manual? This tv may have setting to cut out the picture also when commercials come on. From a technical view point generally commercials have stronger signals than regular programming. This may be overloading your set. If this is the case, then you need to have it checked by good technician. A poorly operating power supply (not regulating properly) could possibly cause a problem like this. Also automatic gain control circuits could be not working properly. Stargazer
Jan 19, 2007 | Hitachi 43FDX01B TV
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
199 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
