Question about Dometic Refrigerators
Our Dometic Americana in our RV is too cold and is freezing everything. We have had the thermal coupler replaced to no avail. Can you help?
Posted by ksteeves328 on
Anonymous
Just tried moving the temp sensor closer to the "fins" in the fridge part...we'll let you know if it works. The sensor is placed in a plastic sleeve that holds it to the fins. I have moved it so the tip of the sensor wire touches the end fin.....
Posted on May 06, 2010
Refrigerator not cooling on electricty or gas
You will first want to ensure the RV is level.
If the RV is level, then open the rear access vent door on the side of the RV to access the rear of the refrigerator. Feel the coils just above the tank on the cooling system. These coils should be warm to the touch. If they are warm and the refrigerator is not cooling then you will require a replacement cooling unit. Also, the most common area for the Dometic 2652 to leak is just above the propane burner area. If it has leaked, you should see a yellow residue in that area. The cooling unit can be changed in approximately 2-3 hours with no specialized tools needed (Arcticold offers 7 day a week free tech support). The old cooling unit will simply unbolt and the new one bolts in. Check out ArctiCold Refrigeration We keep it cold (the highest quality product available) Arcticold New Cooling units come standard with a Lifetime Warranty. Install instructions are also provided with the cooling unit. Arcticold has locations across North America to provide fast delivery. Arcticold cooling units may be purchased over the phone (1-888-782-6665) or through Ebay- Dometic RM2652 Brand New Manufactured Cooling Units LIFETIME WARRANTY
#1 Help Diagnose Video
#2 Install a Arcticold RM2652 Cooling Unit Video
Mar 15, 2014 | Dometic DM2652 Americana Fridge...
A dometic #2862 rv refrigerater which is freezing everything
This one is easy your thermostat is gone. You may notice the unit never shuts off.
Jan 13, 2018 | Dometic Refrigerators
RV ice box freezes everything
if it have a timer board change it
Mar 31, 2009 | Dometic Refrigerators
I have a Dometic RV frige that freezes everything in the frige section even when i have it set on the lowest temp setting
thanks for the question sounds like a defective cold control replace it thanks the appliance doc
Sep 16, 2008 | Refrigerators
Refrigerators Logo
478 people viewed this question
Top Dometic Refrigerators Experts
Sheldon Dedek
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
