Tip & How-To about Saab 9 5
DIY Replacement Ignition KeySubject: DIY Replacement Ignition Key Title: What to do if you need a replacement ignition key Overview: There are times where you may need a replacement key. This can be the cause of a lost key, a key going bad, upgrading from the non all-in-one key to the all-in-one key. Please keep in mind that if all keys are lost, there is NO WAY to program a new key to you car and a replacement TWICE module will have to be found with a key, either new (costly) or used and be married to the car via the dealer. Symptoms: Need a key, key is giving intermittent "bad key" messages and will not start the car, etc. Experience Level: Easy Tools Needed: Probably none, or a small tool to take the door off of a key via the hole in the side for the all-in-one key. Time Needed: Not much. Parts Needed: Key Blank from Dealer about $40 This is cut to your car. Key Top from Dealer about $40 This is the "key guts" all-in-one guts from Dealer about $90 all-in-one guts from ebay about $30-$60 key door from dealer for all-in-one key about $15 Procedure: There are a few cases that can be covered Case 1: Non All-in-one key replaced by non All-In-One key. Subcase A: Have a non all-in-one key that is going bad Solution: The dealer will have a replacement top for the key. Get the top, replace the top of the key and have it reprogrammed for the car. Total cost about $40 + $30. Subcase B: Replace with all-in-one key because they are neato and / or the other key is lost. Solution: Order the "Key Blank" from dealer and obtain the guts for the all in one key from ebay or the dealer. Have keys programmed by dealer. Total cost about $35 + $30 + guts cost. Case 2: All-in-one key replaced by All-In-One key. Subcase A: Have key but is not working. Solution: Get guts and have it programmed. Cost about $30 + guts cost. Subcase B: Lost key, need a new key Solution: Get Key Blank and guts and have it programmed. Cost about $35 + $30 + guts cost. Outcome: Very nice. Replacing the non all-in-one with the all-in-one dramatically increased the range of the remote. over the banana style remote. Notes: - Replace the battery in the guts if you get them off of ebay. - You have to have all keys and remotes to dealer for programming. - The guts for the non all-in-one key do not have the remote guts - The guts for the all-in-one key have the security and remote in one - The key shaft from the ebay all-in-one key can be discarded
Cars & Trucks Logo
2004 Saturn Vue my key wont turn on engine, problems leading to this often won't start have to reinsert key then it works sometimes key falls out and car still running?
Our Professional Tech Jeff provides the answer
It is a known issue
Ignition cylinder replacement DIY? - SaturnFans.com Forums
SaturnFans.com http://www.saturnfans.com > ... > Vue Tech
Sep 27, 2009 - I have run into the very common notchy/sticy ignition cylinder problem on a 2004 Vue. ... $60 for the Saturn lock cylinder on the Vue is starting ...
2007 Vue--ignition, new housing and keys - SaturnFans.com
Sep 30, 2019
Ignition lock cylinder removal question.... - SaturnFans.com
Mar 5, 2006
Free ignition lock cylinder fix.... - SaturnFans.com Forums
Jul 30, 2010
Ignition Lock Cylinder Replacement 2004 Saturn Ion
Mar 20, 2013
More results from www.saturnfans.com
Saturn Vue Ignition Lock Cylinder Replacement Cost
RepairPal.com https://repairpal.com > estimator > ignition-lock-cylind...
The average cost for a Saturn Vue Ignition Lock Cylinder Replacement is between $139 and $174. Labor costs are estimated between $65 and $82 while parts are ...
Videos
LOST MY KEY TO THE IGNITION AND THE DOOR AND NEED TO GET A REPLACEMENT
Two things u can do! Go to the dealer with the Reg and title they will cut u a key threw the vin. Second u can remove the door lock / key cylinder and take it to a lock smith !
The ignition is locked and can not turn the key
Ignition lock cylinder or solenoid damaged. Either way this is a dealer only fix, because the cut codes for replacement lock cylinders and keys are confidential information and require a government issued ID matching the vehicle title.
Top Saab Experts
ZJ Limited
ZJ Limited
john h
Sean Wright
Sean Wright
Are you a Saab Expert? Answer questions, earn points and help others
