I put away my camcorder for the winter and i recently took it back out in order to review some old tapes but it keeps flashing the triangle with the line under it and beeping. when i pull out the door to eject the other door does not come out, also when i put it in record mode it is zoomed all the way in and wont zoom out. i really need help!
SOURCE: camcorder tape door opening
I had a problem the same as yours and I found the problem on the ribbon wire connected to the board where all the control button is located ( stop, rew, play, fwd pause). The problem occur because everytime you eject the tape from the loading mechanism the ribbon wire also move like your cutting it into pieces. sorry for my english hope you get the idea.... wait for the photo and i'll show you what i mean.. hope this will give you the solution you need.
SOURCE: Eject is flashing with fast beeps. Won't eject tape or open compartment.
sad to say that the problem of your camera is the timing gear is already damage....it need to disassembly the camera to fix the timing gear....go to the qualified service center for fixing or replacing the timing gear..
SOURCE: canon elura 60 camcorder zoom is at its maximum and it is stuck .
I have the same probelm how can i fix this.
SOURCE: Reinsert cassette
I've been researching this for hours. I have the same problem. Took it to a repair shop today that would charge me $250 to replace the whole tape mechanism. Finally, I tried the whack trick. I gave the camera a good firm smack on the right side, and voila, now it works! I'm going to tranfer everything to DVD ASAP!
SOURCE: Elura 65 camcorder: Zoom control
Smack the bottom of the camera with the palm of your hand and it will unstick the zoom. Worked for me!
This is usually caused by a failed component in the moisture detection circuitry within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
